Results 1 to 7 of 7
Thread: Stock rims: what tires?
    Oct 2003
    2000 Kaiser
    Another tire question. Looked but didnt find an answer on other threads (might be because im tired too)
    Ok, stock 18 rims. What is the largest tire size i can do (with the lift kit installed) dont want larger then 32/31.5.
    also, what is the widest i can go?
    Understand about the cladding trim, not a problem.
    thought about asking the people at the tire store, but then thought go with who has done it already for best results.
    Thanks
    May 2003
    2001, yellow, 1329
    i just got the nitto terra grappler 285/60/18 and i love them.
    they look great, handle well, are quite and i only had to trim a little of the front cladding (very easy)
    Oct 2003
    2000 Kaiser
    how wide are they compared to the stock tires?
    post pic if you can, of side view and front, thanks
    EDIT: if those are the same as Autox-racer has, kinda small
    2001, proton, 0310
    Yep Itsayjack is steering you true...I have the the 285X60X18 Terra Grapplers too. I think Discount Tire has a conversion formula on there website, but the tire is just short of 31' in dia. and has a section width of around 11+". It looks like the tire that Isuzu designed there gapping wheel wells for the VX.
    These tires are without question(imho) the best set up. bar none. You will have to trim a teensy part of your cladding on the front edge with a jig saw. Takes less than 10 minutes, take about 2 inches from the front outside edge of the cladding and cut at a angle to a point about 6 inches in the direction of the license plate. To get a better idea... turn your steering wheel to where the center of the tread of your present tires are closest to the front bottom edge of the wheel well. Your stock tires will be about 1 1/2 -2 inches from that tip. Just measure up about 2 inches up the cladding and cut at an angle toward that "curled up" lip at the bottom of the front cladding. Your piece should look like a little triangle and not noticable. If it is you cut too much ;eekr;
    I would send some pics if I had them...actually somebody already has on some previous threads. The rear tires fit without mods. I made the cuts first then bought my tires.
    I know some go with 33-34" O.D. tires. for that Monster "Big Foot" look. Not the ideal choice IMO for decent gear reduction on some "hair raising" icy slippery sliding steep downhill sidehill butt puckering 4 wheeling where slow staying off the brake pedal travel keeps you in the road..sorta.
    This tire looks like it belongs there and is a pratical tire for this car.
    Getem and you'll thank me.
    As for the tire rim they recommend 8" and my stock rim is 7" looks fine to me..drives fine...feels fine...I may drop the air down again to 32lbs from 34...just tweeking a little and there.
    May 2003
    2001, yellow, 1329
    here are the measurement differences between the stock 245-60-18 tire and the nitto 285-60-18
    i'll list the stock sizes first:
    sidewall 5.8" vs. 6.7"
    radius 14.8" vs. 15.7"
    diameter 29.6" vs 31.5"
    circumference92.9" vs 98.8"
    revs per min 682.0 vs 641.0
    the speedo reading w/ the nittos is 6.4% too slow. when the speedometer reads 60mph you are actually traveling 63.8 mph
    i made a little chart fto keep in the car.
    the numbers are rounded
    23 mph =25 mph
    28.5 mph =30 mph
    33 mph =35 mph
    38 mph =40 mph
    42.5 mph =45 mph
    52 mph =55 mph
    57 mph =60 mph
    61.5 mph =65 mph
    66 mph =70 mph
    100 mph =106.4
    200 mph = 212.8
    hope this helps.....the tires look great, ride great and are quite.
    May 2004
    No VX anymore. :(
    Just out of curiosity... why did you bother with the 200 mph?
    Steve
    23 mph =25 mph
    28.5 mph =30 mph
    33 mph =35 mph
    38 mph =40 mph
    42.5 mph =45 mph
    52 mph =55 mph
    57 mph =60 mph
    61.5 mph =65 mph
    66 mph =70 mph
    100 mph =106.4
    200 mph = 212.8
    Get a handheld GPS, then you're always right !
  1. Biggest tires on stock rims?
    By Lavx0642 in forum Wheels and Tires
    Last Post: 01/15/2016, 10:48 AM
  2. Replies: 21
    Last Post: 04/03/2014, 02:21 PM
  3. Stock tires on wider than stock rims?
    By Y33TREKker in forum Wheels and Tires
    Last Post: 07/19/2013, 11:33 PM
  4. Fit 4 stock '99 rims and tires in back of VCross
    By yellowgizmo99 in forum VX Talk...
    Last Post: 03/19/2010, 07:04 AM
  5. Replacement tires on 18" stock rims
    By Ebony1433 in forum VX Troubleshooting...
    Last Post: 10/21/2003, 12:07 PM
