dang, I know the feeling. I went with the Yakima Load Warrior. Nothing bigger because the roof space is so small anyway. To accessorize I bought two BOA bike mounts, two Wheel Forks and the Powder Hound for my snowboards. I can have everything but mounted at once too, and I keep it all attached and then pull the whole basket off when I am not using it. Its a pretty sweet set-up if you can see yourself needing the basket, like that is what I will be getting to hold my spare... If you don't see yourself needing the basket, check out the Pirhana Fork Mount: http://www.vehicross.info/forums/sho...ght=bike+mount
-The Rave-
North Carolina
