I want just a mild lift.
If I were to install the 1" coil spacers from Independent4X.com would I need to do anthing else - i.e. lengthen brake lines or longer bump stops?
Thanks
Thanks
That will do fine and bring the back up in line with the front after you tweak the tbars.
