Results 1 to 5 of 5
Thread: Rotor question....
    Feb 2004
    2001, SUPERCHARGED!
    Rotor question....
    Ok, say I order a set of rotors, just to be safe, have them checked before having them put on.
    Is there any way to check to see if they are warped before putting them on?
    Draftsman of the dead
    Mar 2004
    2000 Firefox Red 0758
    You could take them to an auto parts place with a machine shop - they could put them on the lathe and see if they are true ......
    when I was a kid, I worked at a station that put every new rotor on the lathe before they installed them ......
    but it appears many (most ?) places just install the rotors ......
    Feb 2004
    2001, SUPERCHARGED!
    Cool, I plan on just bringing them in to see if they are all straight first...then set up a install.
    I don't want to show up at install and they say one is warped, then go through the hassel and waiting for the replacement....ya hea.
    Jan 2004
    2000 Black Trooper 3248
    jayfotos, I've installed dozens of new rotors on cars. The thought to check for warping has never crossed my mind. Rotors get warped while on the car, not while on the shelf. Are you buying them used? If so, then yes, they might be warped. Otherwise, spray 'em with brake cleaner, and put 'em on.
    Nate
    Feb 2004
    2001, SUPERCHARGED!
    Thanks Nater.
    I just was'nt sure, I hear people say they had warped rotors.....Thought they had'm put on and they were warped apon placement.....not that after use they would warp.
    What a decent warentee for rotors? 60 days after install? life of the car?
    I'm getting a good deal on cross drilled/slotted front and rear rotos and the warentee is 60 days after install.....is this standard warentee?
  1. Need Help Rotor Install
    By Lizardmen3477 in forum VX Modifications...
    Last Post: 11/14/2011, 09:22 AM
  2. rotor spec
    By orion in forum VX Troubleshooting...
    Last Post: 10/11/2007, 05:05 PM
  3. Rotor Swap
    By jgalt in forum VX Modifications...
    Last Post: 07/09/2007, 07:01 PM
  4. Brake rotor issues
    By hitnrun74 in forum VX Troubleshooting...
    Last Post: 08/01/2006, 08:42 AM
  5. rotor blades
    Last Post: 11/03/2003, 06:03 AM
