Results 1 to 5 of 5
Thread: misfire in engine P0300
    Angry misfire in engine P0300
    i need someone's advice,
    my engine just started shaking and the check engine light went on, i run the diagnostic, and recieved P0300 signal - misfires in the engine:
    i have an assumptions that it could be a problem with:
    -sparkplugs
    -coils
    -wires
    Any advice, did anyone had this kind of problem, and how did you deal with this?
    Thank you in advance
    Clogged injectors or plugs probably. If that doesn't do it run a search. There was a resent thread with lots of other stuff to check.
    '99 SC Ebony #1961
    alexeikuchinsky you got some nice high resolution photos on your site... 2272x1704, dammmm
    http://imageevent.com/lesha/vehicrosstestdrive
    So have you guys raced? Hope that our VX is faster??
    Good luck.
    -Dave
    If I remember, the past model Nissan Frontier and/or Xterra was only around 210hp with SC.... I'd say the VX can probably handle it.
    no VX - yet
    Re: misfire in engine P0300
    -sparkplugs
    -coils
    -wires
    Have you changed your plugs lately?? The coil over plug adapters could be your problem. the one that goes on the rear - driver's side is shorter than the others. Check yhe numbers molded in the rubber on the side closest to the intake.
    If you are like me you kept them on the same aide and you will only need to check three to find the odd one. it goes on the rear cylinder.
    FF
  1. Cylinder 4 misfire
    By Joe@lolavisuals in forum VX Troubleshooting...
    Last Post: 07/05/2013, 08:08 PM
  2. p0306- Cylinder 6 misfire
    By Grif in forum VX Troubleshooting...
    Last Post: 04/19/2011, 06:38 PM
  3. Error Code 300: Enigine Misfire
    By mattlewis9333 in forum VX Troubleshooting...
    Last Post: 11/21/2008, 06:24 AM
  4. Misfire/Oil In Spark Plug Well
    By 100kVX in forum VX Troubleshooting...
    Last Post: 06/03/2008, 05:18 PM
  5. P0302- Cylinder #2 misfire
    By olsonjus in forum VX Troubleshooting...
    Last Post: 08/20/2004, 04:36 PM
