Results 1 to 8 of 8
Thread: 35" tire questions
    Talking 35" tire questions
    Hey guys. I got a couple of questions. And yes i did use the search function first . For you guys running 35s, how bad was the effect on power, and on your MPG. How far can you go on a tank? Are there any gears available for the VX? I know for my amigo their were 5.38's available (mine came with 4.56). I know some isuzus ( 94' and up rodeos) came wtih a DANA 44 rear axle. I also think that some of the 4 cyl rodeos came with 4.56, so that might be a cheap swap from a junkyard or something assuming the VX has the same axle.
    Also, i was wondering, what takes more away from an engines performance (MPG and power): Smaller tires on a wider rim (33's on 15x10) or larger ones on a smaller rim (35's on 15x7)?
    '01 Proton 1416
    I can't think of anyone running 35's. Allan was for a while but has since bumped up to 36's I believe. Most of us are hovering around 33 as an upper limit so far.
    Would love to see it, though. ;Dp;
    Brian
    '01 Proton 1416
    Mar 2004
    A-2004
    are 33" x 14.5 " width possible on the VX?
    Aug 2003
    1999,Silver,Vehicross,0928
    holy *****....35" tires....ur vx might end up look like a mini monster truck.....
    ________
    Volcano vaporizer
    01,Black & NEW 01, Green!!!
    My rig has BFG 35x12.5x18's
    "The USA Is Making Enemies Faster Than We Can Kill 'Em!"
    Mar 2004
    A-2004
    Mr. Bam Bam,
    WHAT OME spring did you use and did you add a body lift?
    CALMINI LIFT, but to put 35"'s on, it takes a LOT of trimming of cladding, and also on the metal body support between the front doors and the front wheel wells. Also had to do a few more turns on the torsion bars, to handle any possible contact of the fronts with cladding, when breaking hard. It does work now without any contact, except when crawling thru BIG holes.
    All in all, I think holding at 33" is probably the smartest path to follow in big meat mods.
    Mar 2004
    A-2004
    Seems all off road tires being used are 12.5 width like the BFG's.
    Anybody try the wide look of the Mikey Thompson in the 14.5 width?
  1. tire questions
    Last Post: 11/16/2012, 01:35 PM
  2. 2 Tire Replacement Questions?
    By VXNIT in forum VX Talk...
    Last Post: 11/07/2008, 11:18 AM
  3. "normal" tire sizes
    Last Post: 05/10/2007, 09:52 AM
  4. Just got her, tire questions
    By cascabel3 in forum VX Talk...
    Last Post: 12/10/2004, 03:24 PM
  5. Yet MORE tire questions
    By Ron Pfeiffer in forum VX Talk...
    Last Post: 03/06/2004, 08:23 PM
