Results 1 to 4 of 4
Thread: Any input on this??? Ground Kit??
    100% BRAND NEW IN BOX!! NO MODIFICATIONS NECESSARY.This JDM kit features a central major grounding point that branches off to the major components of the engine.Circle Earth Ground System - block and multiple grounding points, improved idle and drivability are often obtained as the additional grounding points equalize resistance and voltage between various ground points.
    Quicker throttle response.
    Smoother idling and improved starting.
    Cleaner exhaust caused by higher burn rate (decrease of HC/CO density).
    Stabilizes the engine at high RPM's.
    Prevent power loss and ensure top performance of your ignition.
    As a result gain 5-10 HP.It also prevent power loss and ensure top performance of your ignition and other components.
    face the mirror
    Nov 2002
    Wink
    If you believe that I've got some swampland to sell you. It even comes with a bridge and a goldmine too!
    Mar 2004
    A-2004
    Cool
    I got some ocean front property in Arizona. From my front porch you can see the sea... ...if you'll buy that I throw the Golden Gate in Free......
    That what I thought....
  1. Stock Stereo Aux input in palce of CD changer
    By longiotti in forum VX Modifications...
    Last Post: 07/05/2013, 08:19 AM
  2. Input on this idea for exhaust pipe?
    Last Post: 05/06/2008, 09:54 AM
  3. Need some input about a purchase
    By Dumke in forum VX Talk...
    Last Post: 03/16/2005, 10:36 AM
  4. VX Shopping & looking for input.
    By nates33 in forum VX Talk...
    Last Post: 06/04/2004, 04:00 PM
  5. I need input on tires
    By carlymac in forum VX Talk...
    Last Post: 01/25/2004, 02:24 PM
