P285/60R18's and wierd TOD Operation
Got my P285/60R18 Nitto Terra Grapplers installed last week, they are pretty awesome, looks are 10 times better and the handling feels about the same as the 255/60R18's I had before, and I push my VX hard. Ride is a little harsher but is expected since the air volume is greater (pnuematic stiffness overrides the extra section height benefits). I was concerned about being that wide on a narrow 7" rim, that handling would really tank, but its great. And just a bit noiser.
Anyway, my TOD is now acting wierd. From a start, wet or dry, the TOD goes to full (3) leds then back to none, then back to (3) at least once or twice while accelerating. This is only around 0 - 20 mph and at part (halfway) throttle. Anything less and its the normal 1 led, anything more and it might spike to 3 then back to 2 as normal under full throttle (unless its really slick of course). I can physically feel the power going to the front and then all back as it cycles. At anything above 20 mph its good. I have no check TOD light flashing, I do have a TOD cutoff switch installed, but this just started with the tire change. Is the larger OD of the tires thowing off the TOD? Is there a way to reset the TOD or read codes? Is anyone else experiencing this with there larger Nittos?
Thanks!
Mike Skurich
1969 C3 Corvette Coupe
1988 C4 Corvette Coupe
1992 Misubishi 3000GT VR4
1997 BMW F650ST
2001 VehiCROSS
2002 BMW R1100S
2005 C6 Corvette Coupe
