Results 1 to 6 of 6
Thread: Front Marker
    Jan 2004
    1999 Silver VCross 1925
    Front Marker
    I have no idea how water is accumulating in the driver side turn signal howsing. I removed it for inspection and nothing seems cracked or broken. Any ideas or suggestions?
    Thanks,
    Julio
    Aug 2003
    1999,Silver,Vehicross,0928
    theres suppose to be a rubber seal there. check and see if hte seal thing is still there.
    ________
    Aromed 4.0 Vaporizer
    Jan 2004
    Everything is sealed as it came from the assembly line. I even tried to take it apart and reseal it, but there was no need for that, as it is tight on all sides.
    It is very weird but water still gets in. I think my VX is haunted!
    Feb 2004
    2001, Ebony Black, VX, 0432
    Has the yellow lens from your signals ever been removed for bulb changes or anything else? There are 2 little square notches cut on the bottoms of each lens. I would assume that one purpose for these cuts is to allow water and/or mositure to drain out of the housing. Is is possible that your lens are on upside down? I know that there's a "top" indicator on the lens and they don't fit on the proper housing if upside down, but if the left lens is upside down on the right housing and the right on the left, they will fit and the drain notches will be pointing upwards (basically allowing even more water/mositure into the housing).
    JUST A THOUGHT
    But yeah, the white rubber gasket missing from between the lens and housing would be the most common cause.
    Is there a vent tube on the backside? It should face down.
    Try removing it, draining it tape off all visible openings and then submerse it it a bucket, watch for bubbles. If you can't find the leak then drain it and let it sit in the house for a week to dry it completely. Reinstall it and if it accumulates water again replace with new.
    Jan 2004
    I'll try that, thanks!
  1. marker light removal?
    By ipd in forum VX Modifications...
    Last Post: 05/15/2017, 05:15 PM
  2. LED (or smd) for f/r marker lights
    Last Post: 09/07/2014, 07:29 AM
  3. LED Front marker & Turn Signal Mod
    By Tookie in forum VX Modifications...
    Last Post: 09/26/2010, 04:29 PM
  4. Marker lights
    By JAG! in forum VX Troubleshooting...
    Last Post: 12/17/2003, 05:18 PM
  5. Marker Lights
    By Leah in forum VX Troubleshooting...
    Last Post: 11/17/2003, 02:21 PM
