Results 1 to 4 of 4
Thread: Bump Stops Aid Handling?
    Mar 2003
    2001, Kaiser Silver, 0482
    I just installed the P285/60R18 Nittos and also did a 1" poly spacer lift in back ( and crank up the front T-bars an inch as well). I knew I would loose some handling, but its not so much the handling as the tires are great but the body lean is more than I would like (which is expected). Its also why I only went with a 1" lift. Anyway, what roll do the bump stops play in body roll, or are they only to keep the tires from hitting inside the wheel wells? I know the stock ones sat only about 1/4" or so from the rear axle, so they had to contact quite frequently and help with body roll. Can I simply fabricate some extenders or are the older Trooper bump stops and 1" or so longer.
    Not sure what to do about the fronts, I believe those are a little farther from bottoming.
    Mike Skurich
    1969 C3 Corvette Coupe
    1988 C4 Corvette Coupe
    1992 Misubishi 3000GT VR4
    1997 BMW F650ST
    2001 VehiCROSS
    2002 BMW R1100S
    2005 C6 Corvette Coupe
    Mar 2004
    2000 Firefox Red 0758
    I suggest a look at Rickster's photo gallery .........
    there is some good 'bump stop' stuff there ..........
    2001 Proton VX 0790
    If you are leaning in a turn, on the bumpstop, it is adding to the spring rate.
    Once the bumpstop fully compresses, bad things happen. The instant center will change to the contact patch of that tire, and that will cause loss of grip.
    John C.
    Mar 2004
    A-2004
    Bumpstops?
    I don't think he meant those Bumpstops.
  1. rear bump stops
    By vxfocus in forum VX Modifications...
    Last Post: 10/13/2012, 08:59 AM
  2. Bump stops
    Last Post: 09/13/2012, 03:29 PM
  3. Bump Stops (again)
    Last Post: 03/03/2011, 02:00 PM
  4. Bump Stops
    By JAMAS in forum VX Talk...
    Last Post: 04/15/2009, 06:02 PM
  5. Rear Bump-stops
    By kelvin in forum VX Troubleshooting...
    Last Post: 05/31/2007, 02:23 PM
