I am thinking of taking the plunge and getting a rear view camera and was wondering what kind people have? and what size will fit in the half moon?
thanks
adam
thanks
adam
i got mine from tone. u can check his site
http://tonemonday.com/accessories.htm
this is how i mounted tat camera
http://www.vehicross.info/gallery/da...800600-med.jpg
________
Marijuana card
Have you ever tried to use that camera while driving at night? Is there any problem with the headlights from cars behind you (glair and such)?
thanks
adam
Any camera aimed a bright light in the dark will experience some glare and it depends on where it is aimed. These cameras come with adjustable amounts and are best suited to look directly at the area you cannot see from the front seat. You can certainly aim it more out the back to see farther down the round but then it would not cover the blind spot that is directly behind the VX..
I use 2 on mine - one forward facing and one rear facing and love them!
like tone said it auto adjusts so if it gets bright all of a sudden the camera adjusts and darkens the picture...also i have it hooked up to the reverse light so it only comes on when i have it in reverse. makes parallel parking alot easier......
________
The Vision Condo Pattaya
