with a warning or 'dummy' light, the light will (generally) only illuminate when there is a problem .........
when the oil pressure drops to zero - or close to zero - it will illuminate.
Not good.
....... and - the oil level must be *VERY* low for the oil pressure to read zero .......
Try to check your oil whenever you fill your gas tank, it only takes a minute, and you'll be able to identify issues before they become problems. Let's hope there was no serious damage done
