Results 1 to 5 of 5
Thread: Brake fluid
    Mar 2003
    1998 Blue standard 1198
    Brake fluid
    My Japanese spec VX brake fluid needs topping up, I have tried to obtain DOT3 as it states on the cap but so far no luck. Having read on the cans of DOT 4.1 and 5 that it exceeds the spec of DOT3 I am a little wary as the existing DOT3 may be synthetic and the DOT 4.1 or 5 may be a different base material can anyone shed any light on this subject?
    2000 Dragon Green VX 0485
    Dot 3 &4 are Glycol based & absorb water. Dot 5 is silicone based and does not absorb water. You state that you are topping off. Do not use Dot 5 to top off brake system with Dot 3 already installed. Actually consider draining & flushing the Brake system & refill with Dot 5.
    Dot 3 & 4 also have lower boiling points then Dot 5
    Bob
    Would it be safe to say that Dot 5 is superior to the others?
    Since Dot 5 does not absorb water there is always a chance that if water somehow enters your brake system it will cause rust wherever it is contained.
    Bob F
    Mar 2003
    Thanks for your reply Green Dragon, as I am only topping up I will use the readily available DOT4.1
  1. Loose Brake Fluid Cap
    By mdwyer in forum VX Troubleshooting...
    Last Post: 12/04/2010, 05:24 AM
  2. Brake Fluid Leak From Vacume Booster
    By crotchrocket in forum VX Troubleshooting...
    Last Post: 07/02/2010, 03:38 AM
  3. Synthetic Brake Fluid?
    By VXNIT in forum VX Talk...
    Last Post: 07/23/2007, 04:46 AM
  4. Brake Fluid vs. Power Steering Fluid
    By TEN36VX in forum VX Troubleshooting...
    Last Post: 07/01/2006, 03:12 PM
  5. Brake fluid question
    Last Post: 04/15/2004, 09:28 PM
