Results 1 to 5 of 5
Thread: Easy Horsepower
    Nov 2002
    Lightbulb Easy Horsepower
    Here's an easy, but not necessarily cheap, mod to get you about 15 - 20 additional ponies on the dyno: ExtrudeHone.
    You'll need to send in your intake, so this may not be ideal for those without additional transportation options, unless you pick up an extra intake from eBay or a salvage/junk yard. But it is a proven and effective performance increase.
    If 6 or more are interested we can get a Group Buy on this as well. You can count me as number 1!
    '99 SC Ebony #1961
    Question
    Will this work or not work with my SC?
    Basically this process smooths out the burrs and rough spots in your manifold and heads to allow a smoother flow through the system like polishing. This has been going on for many years with the race car/hot rod scene. It should not matter weather your S/C'd or not.
    $1725 for heads, exhaust manifold and intake manifold....ouch!
    A bit cheaper for a group buy! That is exspensive horsepower.
    You can do the same thing at home with a dremel tool!
    That's a LOT of loot for the inconvenience and small hp gain. As Triathlete stated, it's not a new process, so a local speed machine shop could probably offer that service. I don't know about the need to send it out to have it done. *shrug*
    Nov 2002
    Lightbulb
    I was thinking of JUST the intake, which would net the mentioned gains for about $600. Doing the all the rest is extreme and should only be considered for a full-prep engine job.
    As for a local speed shop doing it, yes there are a few that have the proprietary ExtrudeHone equipment and training but even more who "do their own thing" at your potential expense. I generally believe in going to the source for this kind of work.
    I haven't really looked closely at the guts of an SC install so can't answer that question, so hopefully Tone will chime in.
  1. 1.5 liter....533 horsepower!
    Last Post: 12/23/2010, 06:55 PM
  2. horsepower
    By byrona64 in forum VX Talk...
    Last Post: 10/06/2008, 05:54 PM
  3. how to boost horsepower
    By Randy Floyd in forum VX Modifications...
    Last Post: 05/16/2003, 01:42 PM
  4. Torque & Horsepower n stuff
    By Green Dragon in forum VX Talk...
    Last Post: 05/10/2003, 11:24 AM
  5. S/C Horsepower: Do the Math
    By Baxman in forum VX Talk...
    Last Post: 11/20/2002, 09:50 PM
