Results 1 to 2 of 2
Thread: Rubber Headlight Gasket
    2001 Proton 0951
    Has anyone replaced the rubber headlight gasket? Both of mine came off and I can't get them back in. Will this require a mechanic or is it something I can do.
    Thanks for your help!
    Life is what happens when you're driving a VX...
    Jan 2004
    1999 Silver VCross 1925
    Actually, just remove the headlights and then get some silicone glue and get them back in there. If you decide to get new ones from St Charles, they are about 15 bucks a piece, not bad. I will still re-enforce the factory adhesive with silicone because it will happen again and again and again. I did it with House clear adhesive (all purpose), applied it to the old gaskets and they haven't come off in over two years.
    Julio
  1. Missing headlight rubber alternative....
    Last Post: 09/21/2009, 12:33 PM
  2. rubber gasket around front headlights
    By glock in forum VX Talk...
    Last Post: 07/15/2007, 04:58 PM
  3. Rubber Headlight Gasket
    Last Post: 10/30/2006, 06:01 PM
  4. Headlight Gasket Fix
    By EclipseGSX in forum VX Modifications...
    Last Post: 10/27/2003, 05:28 PM
  5. headlight rubber gaskets...
    By jester0064 in forum VX Troubleshooting...
    Last Post: 09/04/2003, 11:59 PM
