Results 1 to 3 of 3
Thread: Instrument Panel Burn Out
    Feb 2004
    2000 Black VX 0173
    The lights for the RPM and Speedometer have gone out! (Gear Indicator, TOD, and Warnings all work)
    1: Anyone know where these light bulbs are? Easiest way to get to them? I thought possibly a fuse, but couldn't determine which controlled the instrument panel.
    2: While I am at it, my dimmer has never worked since I bought the VX. Any suggestions on the possible cause? Or solution!
    Thanks, and sorry for the amatuer questions?
    p.s. i already "did a search"
    1999 silver 1346
    I have a similar problem, my power switch light on the dash board just went out, Anyone know if i have to take the whole dash apart for this, I know that the switch still works cause i still feel the diffrence in the power.
    As far as your dash lights, mine went out the other day, cause was a blown fuse in the drivers side pannel, I think it is linked to tail lights. Also the dimmer light has a connector in back of it, maby that got disconnected, Its worth a try
    adam
    2001,Ebony,VehiCROSS,1092
    You say your lights for the tach & speedo are out - how about the gas & temp gauges? If those are out as well, it's probably a fuse. If it is light bulbs, you'll have to remove the dash face plate, remove the 4 screws holding the instrument cluster in place, and pull out the cluster far enough to get at the bulbs in the back. This sounds (&looks much more daunting than it actually is - shouldn't take much more than 1/2 hour to take apart & put back in. The bulbs are 194's
  1. Any Ideas on Instrument Cluster Graphics???
    By BeeVenom in forum VX Modifications...
    Last Post: 08/03/2009, 02:45 PM
  2. New instrument cluster stripe.
    By kodiak in forum VX Talk...
    Last Post: 12/01/2008, 06:11 PM
  3. door panel
    By harvey phillips in forum VX Troubleshooting...
    Last Post: 10/04/2008, 12:12 AM
  4. CF Panel Replacement
    By circmand in forum VX Troubleshooting...
    Last Post: 10/23/2007, 09:03 AM
  5. Dead short in Rear Light/Instrument light
    By Damien Jones in forum VX Troubleshooting...
    Last Post: 07/16/2006, 08:49 PM
