I'm interested in seeing everyone's aftermaket or modified intakes, just curious on what people are doing out there.
Thanks- Jay
Thanks- Jay
Draftsman of the dead
Most impressive, very nice.
Bob F
im guessing tats the hotshot intake?Originally posted by Cyrk
________
Zoloft lawsuit
Now this is interesting....
I'm noticing, now please forgive my lack of terminolgy. From the intake tube, there is a intake line, on mine runs across and infront to the left side of the engine.
Yours, you have from what looks like going back through and out to the wheel well and a small filter on your engine.
What the purpose in that and why?
Inquiring minds would like to know.....
I know a lot of people say about heat soak and trying to get the cold air in from outside the vehicle, but does'nt that little filter defeat that purpose by sucking in hot engine heat?
 Super VXer
						Super VXer
						Jay, it's a crank case breather filter. The crank case expels gasses through the hose back into the intake. The filter filters out the gases/oil. I just put a fuel filter on mine and plugged the hole in the intake.Originally posted by jayfotos
I see Cyrk also has the coolant bypass as well, as I do. I also plugged the hose going out of the PCV valve, and put a fuel filter on the valve as well.
How does all that help?
Optima Redtop is starting battery.
Optima Yellowtop runs Warn XD9000 Winch and 400 watt audio amp.
160 Amp Alternator sends charge to a 200 watt battery isolator charging either battery as needed.
Calmini air filter.
Tornadoe inside intake hose.
Extra 12 inch auxillary cooling fan beside stock 10 inch fan.
These are the ones I've made up. My next step will be a straight tube from the filter to the throttle body.
John C.
MZ-N10, It is part Hotshots and part VW Golf intake.
 Super VXer
						Super VXer
						Dude jayfotos when are you going to be around? I have to meet up with you and check out your ride...
 Super VXer
						Super VXer
						The coolant hoses that run into and out of the top of the intake manifold circulate coolant through the manifold for warm cold-engine starts. It heat up the manifold (circulating warm coolant through it) so the engine starts better on cold days... if you live in a wamrer climate you may consider bypassing the manifold by just taking both hoses off the top and adding a "barb" or fitting in between (joining both hoses together). Some say you can gain a little horsepower this way... I think I feel a difference, maybe not.Originally posted by jayfotos
The crank case expels a little gas back into the intake, which goes back into the manifold and engine. Adding a filter keeps the gasses from going back in... whether it helps of hinders, I don't know. You'll hear both sides, but I think many agree it is just cleaner.
Anytime, PM me and I'll give you my #.Originally posted by VCAMILO
Jay
I might try the bypassing of the coolant, I'll talk it over with my shop guy...it's waaaay to hot here and that might help.Originally posted by Dallas4u
Thanks- Jay
