Originally posted by carlymac
Over the weekend I replaced the PCV valve and did an oil change...switched to synthetic oil. Anyhow when I removed the PCV valve the rubber grommet that the PCV valve seats into broke. In this grommet there seems to be a round ridge inside the engine that the PCV valve snaps into. Does anybody know if the rubber grommet is a dealer part or can it be picked up at a parts house? I installed the new PCV valve but it seems to be a bit looser than the origional PCV valve. Has any of you had this problem replacing the PCV valve?
I think these threads might/should answer your question:
http://www.vehicross.info/forums/sho...ht=pcv+grommet
http://www.vehicross.info/forums/sho...hlight=grommet
