Results 1 to 15 of 19
Thread: Coolant leak! Help!!!
    Aug 2004
    01, Kaiser Silver, VX, 1102
    Doe water pump weap ole only leak when motor is off? Seems mine is only leaking very slowly when setting 24 hours or so. No hissing or smell at all..
    '99 Ebony Black VX, 0339
    It may be leaking when engine is on but so slowly that there is no trace. Weep hole was designed just for that reason - overnight it'll leave a puddle. Make sure it isn't the coolant manifold where the top hose connects that isn't leaking - for more likely. I have a used water pump if that turns out to be the prob.
    Aug 2004
    ANy pics of coolant manifold ? Is this under intake manifold at front of motor or is it visible?
    Aug 2004
    I am still under warranty adn am scheduled for a littel road trip to nearest Isuzu to me since two others have folded. Just want to be sure I can narrow down likely culprits before they tear her down and say all it is this and oh, sorry not covered. I knwo H20 pump is covered if the weap issue is my problem. I only get leak from behaind timing gear and out bottom of the timing cover.
    Aug 2007
    2001, Proton, Vx, 0000
    VXNIT - Did you ever take it into the dealer in Sanford, what was the outcome?
    Also, do you have any pics of the leak itself?
    I've got to make a trip to Sanford due to a powertrain issue (I think) so it'll help to know what their level of expertise and sense of customer service is.
    Cheers
  1. Antifreeze / coolant leak... GRRRRRR!!!!
    By ZeroSix in forum VX Troubleshooting...
    Last Post: 08/13/2012, 05:20 AM
  2. Coolant Leak, Alternator Died... NEED HELP!
    By UWVX89 in forum VX Troubleshooting...
    Last Post: 03/09/2012, 06:49 PM
  3. Coolant leak
    By VXNIT in forum VX Talk...
    Last Post: 10/02/2010, 08:52 PM
  4. Coolant Leak question
    By atilla_the_fun in forum VX Troubleshooting...
    Last Post: 04/19/2010, 03:03 PM
  5. Coolant leak ?
    Last Post: 02/26/2009, 08:34 AM
