Venom Performance has high flow injectors and a high flow fuel pump for Honda Passports. Would they work on our engines? Could be a way so you supercharged guys could use more boost without having to add an extra fuel injector to the motor.
Stock pump and injectors can flow plenty of fuel for higher boost but the ECU can't regulate or deal with it at this time.
