Results 1 to 3 of 3
Thread: Headlight bulbs
    Sep 2004
    99, Silver, #1962
    Headlight bulbs
    Can someone plese tell me how to take out the headlight bulbs, thanx
    '01 Ironman #1109
    Here's some basic steps but if you want more setailed info, do a search through the archives:
    passenger side (battery side):
    1. Remove the electrical plug by reaching behind and dig deep into the rubber boot where the wires run through. Feel for a plastic plug clip, pinch hard, and pull back. The plug should come out with some effort.
    2. Once wire plug is removed, then find small rubber tab on the rubber boot and pull back. Boot should slip off the housing.
    3. You'll see the prongs of the bulb being held in place with a wire clip. DO NOT REMOVE THIS CLIP as it is a pain to put back in place. Best is to use needle nose pliers, grab the end of the wire clip near the slot opening and "undo" the clip. The bulb will then come un fastened and can be removed.
    4. Replace the bulb and do everything stated above in reverse.
    driver's side:
    1. Remove the entire air box and components to gain access the bulb.
    2. Follow the same instructions as above.
    Estimated time (first time around) approx. 2 hours. After much practice (3rd/4th time), 20 minutes total.
    Good luck and don't panic.
    www.aftershockproducts.com
    Sep 2004
    99, Silver, #1962
    thanx alot
  1. LED Headlight bulbs
    Last Post: 03/30/2015, 04:53 AM
  2. Removing headlight bulbs; any 'how-to' write-ups?
    By PHO2GR4 in forum VX Modifications...
    Last Post: 02/08/2007, 05:49 AM
  3. New headlight bulbs...
    By djkymar in forum VX Talk...
    Last Post: 11/09/2006, 09:15 AM
  4. replacing headlight bulbs....
    By Cyn in forum VX Talk...
    Last Post: 04/19/2005, 11:22 AM
  5. Headlight bulbs
    By Anita in forum VX Talk...
    Last Post: 10/10/2004, 05:52 AM
