Results 1 to 15 of 16
Thread: Aluminum Radiator
    2000,silver,vehicross,0460
    Aluminum Radiator
    Here's another possible engine dress up option -- aluminum radiator
    Does anybody know if any of these will fit?
    http://www.jegs.com/cgi-bin/ncommerc...omepage=081004
    Jul 2004
    2000 Black VX 0363
    Whether it will fit is a direct relation to the formula of (Time x Money)
    That being said, if you could find the right dimensions or closeabouts, I'm sure it wouldn't be too difficult.
    Be sure to get a transmission cooler while you're at it. (because that one doesn't have one)
    2000 Black VX 105k
    I have a Ron Davis (Az.) radiator and electric fan shroud for the VX. Davis now has the VX template and you can order one. It has the trans cooler built in.
    Pricey at $600-700.
    Since I moved to Oregon, I haven't felt the need that I did in California. I will post photos when I get it in.
    Roy
    Could you post contact info for him?
    2001 Proton VX 0790
    http://www.rondavisradiators.com/
    Newthings: Let me know if you want to unload that rad.
    John C.
    John,
    Getting the rad was a long fight, but the next guy can order off the RD product list. I will get it and the fan in this winter. Photos to follow.
    Roy
    Mar 2004
    A-2004
    Roy,
    Is there a part number or something to reference the Rad other than state for a VX? The shop is just down the way from me.
    Thanks,
    Andrew
    I can't remember the reps name, but we went over that the rad could be identified by asking for the Isuzu Vehicross. My name may be in the files, also.
    Roy Hackett
    2001 Proton VX 0790
    Any update on this?
    Now that its getting hot again I have renewed interest.
    John C.
    Aluminum Radiator
    Apr 2003
    1999,white,ironman,1497
    Question Ron Davis Not Aware
    I contacted Ron Davis and he claimed ignorance on having done a radiator for a Vehicross
    Said I needed to provide him an invoice number and date...
    do you have that info......or maybe you can call him up and refresh his memory
    And how about some of the installed pictures?
    '99 SC Ebony #1961
    Nice looking, so what will this do for me? Are there any performance benefits?
    The build sheet number off of my radiator is 5225. Contact Dwane (ext 6) at Ron Davis and he will be able to find the product details to build more.
    Also, the fans shroud with two fans has a seperate build sheet number. Dwane should have that in the same file.
    Cyrk,
    If you are running hot, this will make you less hot.
    The rad is about twice as thick as the stock rad. This unit has a trans cooler, but further cooling can be had by remoting the trans cooler. I looked and space is a real problem, so I had the trans cooler built in (As stock). I am adding a trans temp sensor to quantify just how hot the trans oil gets. If you can find a place for a remote cooler, you should make a BIG improvement for few bucks by keeping the stock rad. Since trans oil needs to be hot to work properly, a temp operated bypass is used on remote units to recirc oil until the temp comes up. Using the remote cooler inline with the stock cooler should put you somewher in between, but not needing a bypass.
    Tone,
    Install is less urgent in Oregon than SoCal, but I will get it done. Stock fan will not be used.
    Roy
    Why do you think more cooling is good, especially in your state? Our engines are designed to work best around 190 degees water temp, cooler could leave more deposits in the cylinders. Tranny's are designed to work at a very certain temp and the vehicle's cooling system is designed to maintain that temp unless towing.
    Why not put a gauge in FIRST and see what it runs at before you change from the stock design. I'm just having trouble understanding the time and money to replace a system that essentially works fine, as it was designed to. I saw no performance or mileage gains from removing the stock mechanical fan.
  1. VehiCross Aluminum Name Plates
    By tysamigo in forum VX Modifications...
    Last Post: 01/17/2016, 06:37 AM
  2. Where Can I Buy Aluminum?
    By transio in forum VX Modifications...
    Last Post: 10/02/2015, 04:59 PM
  3. Aluminum Radiator
    By newthings in forum VX Modifications...
    Last Post: 06/05/2014, 06:56 AM
  4. WOW! -55F+Aluminum Rims= 0 psi
    By Kenny in forum General Tips...
    Last Post: 01/13/2007, 01:55 PM
  5. VX Brushed Aluminum Trim - Anyone here??
    By Yefim in forum VX Modifications...
    Last Post: 12/14/2002, 09:29 PM
