Results 1 to 8 of 8
Thread: More info about Tone's Cameras?
    Jan 2004
    2000 Black Trooper 3248
    Tone (or others) do you have more info about the cameras you have for sale? Dimensions? more photos? Viewing angle? NTSC format? Wiring? (Length? voltage? pinouts)? Environmental conditions? (Freezeproof? Waterproof?) Nightvision?
    Nate
    Fits the VX after looking years for the right camera that fits without
    ANY mode of the crescent other than removing the rectangular plastic piece already there for this use - Infrared cameras usually require some modification of the crescent. Cable is plenty long to reach from the back of the VX to the dash or rear view mirror and offers mirroring capability depending on your screen input.
    I have 2 of these on my VX, one rear view in the crescent that activates automatically when I select Reverse or when using my turn signals. It and the front camera can be switched on manually as well by the head unit. I also have these installed on a buddies repo tow truck that he uses for night snags when he does not want to turn on his flood lights. Sees in almost total darkness.
    0.02 Lux CCD Color Camera
    MODEL NO RV-C-32
    IMAGE SENSOR 1/3" inch CCD Image Sensor
    CCD EFFECTIVE PIXELS NTSC 537(H)*505(V) / PAL 537(H)*597(V)
    SCANNING SYSTEM NTSC 525 lines, 60 fields/sec / PAL 625 lines, 50 fields/sec
    SYNC SYSTEM Internal
    MINIMUM ILLUMINATION 0.02 Lux
    VIEW ANGLE 150
    RESOLUTION 380TVL / 470TVL (Enhanced)
    SIGNAL TO NOISE RATIO 52dB(MIN) / 60dB(TYP) (AGC OFF)
    WHITE BALANCE ATW/AWB/FIX SWITCHABLE (Zero color rolling)
    WHITE BALANCE RANGE 3200---15000K (2200-15000K with S Filter)
    AUTO IRIS A.E.S
    ELECTRONIC SHUTTER NTSC 1/60~1/120000sec / PAL 1/50~1/120000sec
    VIDEO OUTPUT 1.0V p-p composite video at 75 ohm
    GAMMA CORRECTION 0.45
    MIRROR FUNCTION ON/OFF wirecable switchable
    GAIN COMTROL AGC
    OPERATION TEMPERATURE -20C TO 50C
    POWER SUPPLY DC12V / 120mA
    WATERPROOF YES
    VARIABLE MODELING Drilled Type & Mounted Type Multi-Function Design
    EXTERNAL SIZE (CM) 58W x 44H x 43D
    PATENT COUNTRY China & Taiwan
    .5 lux camera specs
    0.5 LUX CCD Color Camera
    MODEL NO RV-C-M
    IMAGE SENSOR 1/4" inch CCD Image Sensor
    CCD EFFECTIVE PIXELS NTSC 512(H)*492(V) / PAL 512(H)*582(V)
    MINIMUM ILLUMINATION 0.5 Lux, F1.2
    VIEW ANGLE 130(Diagonal; 110 (H); 69 (V)
    WHITE BALANCE Auto high speed white balance (Zero color rolling)
    AUTO IRIS A.E.S
    GAIN COMTROL AGC
    WATERPROOF YES
    EXTERNAL SIZE (CM) 58W x 33H x 43D
    Past Owner
    Tone,
    Do you have any pictures of your "mod free" camera installation?
    I thought I had posted before but not sure why - will remove the crescent this weekend for a pic of the actual mount - only drilling required is 2 small screws to mount the base of the camera to the metal inside the crescent. Here is one from the outside (my opening nicked due to fitting many different windows to protect old non waterproof cameras) - new camera covers are black BTW:
    Feb 2004
    2001, SUPERCHARGED!
    Looks like you can stick your finger in that hole, waterproof? Sure, maybe the camera but it looks like water can enter and build up into the rear door.
    Draftsman of the dead
    Aug 2003
    1999,Silver,Vehicross,0928
    i have one of tones cameras, and i took a slighty approach to install it
    ________
    Infants Zoloft
    Past Owner
    MZ-N10, I am about to install one of Tone's cameras. Would you please post or PM me with a picture of the back of your installation along with any install info you care to share? Thanks in advance.
  1. Palm Coast gets red light cameras
    Last Post: 12/21/2007, 07:27 AM
  2. A new poll. Speed Cameras
    By Chopper in forum Polls
    Last Post: 12/19/2007, 04:07 AM
  3. Thank you Tone
    Last Post: 06/24/2005, 05:19 PM
  4. Tone! HID Kit?
    By marximus in forum VX Talk...
    Last Post: 12/31/2004, 12:30 AM
  5. Importance of Disposible cameras
    By azskyrider in forum VX Talk...
    Last Post: 04/12/2004, 09:58 AM
