Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: TeraFlex Lower Low?
  1. #16
    Apr 2003
    1999 Astral Silver 1222
    I believe 4.77's are available for the older trooper styles and are intended for 31" tires. They were also a factory option. They wont work for us. That generation has the 10 bolt rear and ? front. When they went to the 2nd gen, they took the larger back and used it up front and slapped an even larger 12 in the rear so f and r got a size increase. thats same as ours. our only option is the 5.38 as far as I know (in the US). 5.38's used on troopers brings the gearing with 33's to about stock again and the speedometer is accurate again. So if 33's is what you want, and stock ratios is what you want, go with the 5.38's. If 31's is what you want, the 5.38's will lower your gears a little. Great for 4wheeling, acceleration, not for gas mileage, not for top speed. I still cant believe all the VXers that keep wanting 1/4 mile times faster, but dont do gears.
  2. #17
    Sep 2004
    '01, Dragon Green, VX #0250
    I can not thank everyone enough for all there input from the posts, I am going for the 5.38's soon now.
    MHE
  1. How to Lower Front Seat
    By mrtew in forum VX Modifications...
    Last Post: 12/29/2012, 06:30 AM
  2. Jeep Lower Forty
    Last Post: 01/05/2011, 02:28 PM
  3. lower intake
    Last Post: 08/25/2010, 04:40 AM
  4. Lower Gear ratio better mpg?
    By l.groves in forum VX Modifications...
    Last Post: 04/29/2010, 04:55 AM
  5. lower my VX
    By jacobus in forum VX Modifications...
    Last Post: 05/28/2006, 10:51 PM
