Results 1 to 8 of 8
Thread: Technical Service Bulletins (TSB)
    Mar 2004
    A-2004
    Office of Defects Investigation
    Technical Service Bulletins - Search Results
    Report Date : October 5, 2004 at 01:43 AM
    TYPE : VEHICLE
    YEAR : 2001
    MAKE : ISUZU
    MODEL : VEHICROSS
    Make : ISUZU Model : VEHICROSS Year : 2001
    Service Bulletin Num : 0301S002 Date of Bulletin: MAY 01, 2003
    NHTSA Item Number: 10001772
    Component: ENGINE AND ENGINE COOLING:ENGINE
    Summary:
    THROTTLE BODY MOUNTING BOLT TORQUE SPECIFICATIONS. *TT
    Service Bulletin Num : IB0108S001 Date of Bulletin: FEB 01, 2001
    NHTSA Item Number: 619824
    Component: OTHER
    Summary:
    INFORMATION BULLETIN CONTAINING QUICK REFERENCE GUIDE CORRECTIONS FOR VARIOUS 2001 MODEL YEAR VEHICLES INCLUDING THE 2002 MODEL YEAR AXIOM. *TT
    Report Date : October 5, 2004 at 01:35 AM
    TYPE : VEHICLE
    YEAR : 2000
    MAKE : ISUZU
    MODEL : VEHICROSS
    Make : ISUZU Model : VEHICROSS Year : 2000
    Summary:
    Service Bulletin Num : IB0004S007 Date of Bulletin: DEC 01, 2000
    NHTSA Item Number: 615681
    Component: ELECTRICAL SYSTEM
    Summary:
    SERVICE INFORMATION ON C-31 GROUND CONDITION. *TT
    Service Bulletin Num : SB0001S005 Date of Bulletin: APR 01, 2000
    NHTSA Item Number: 612584
    Component: ENGINE AND ENGINE COOLING:ENGINE:GASOLINE
    Summary:
    EXPERIENCING INTERMITTENT ROUGH IDLE AND / OR THE MALFUNCTION INDICATOR LAMP IS ON WITH DIAGNOSTIC TROUBLE CODES P0171, P0174, OR P1171. *TT
    Service Bulletin Num : IB0011S003 Date of Bulletin: APR 01, 2000
    NHTSA Item Number: 612586
    Component: EXTERIOR LIGHTING:HEADLIGHTS
    Summary:
    SERVICE INFORMATION REGARDING HEADLIGHT AIMING PROCEDURE. *TT
    Service Bulletin Num : IB00S007 Date of Bulletin: FEB 01, 2000
    NHTSA Item Number: 614137
    Component: OTHER
    Summary:
    ON SUV VEHICLES WITH AUTOMATIC TRANSMISSIONS, SOME REMOTE STARTER INSTALLATIONS MAY CAUSE THE MALFUNCTION INDICATOR LIGHT TO SET AND STORE P0705. AMERICAN ISUZU MOTORS DOES NOT SELL REMOTE STARTER KITS AND DOES NOT RECOMMEND ANY PARTICULAR INSTALLATION. *TT
    Service Bulletin Num : IB00S005 Date of Bulletin: FEB 01, 2000
    NHTSA Item Number: 614139
    Summary:
    THIS INFORMATION BULLETIN OUTLINES THE PROPER STEPS TO INDEX THE CAMSHAFTS WITH THE CRANKSHAFT FOR VEHICLES EQUIPPED WITH DIRECT ATTACK DOHC 3.2L / 3.5L V6 ENGINE. IN THE EVENT THAT CAMSHAFT TIMING HAS BEEN DISRUPTED, DUE TO TIMING BELT BREAKAGE OR CAMSHAFTS / CRANKSHAFT BEING ROTATED WITHOUT A TIMING BELT, THIS IS IMPORTANT PRIOR TO TIMING BELT INSTALLATION. *TT
    Report Date : October 5, 2004 at 01:42 AM
    TYPE : VEHICLE
    YEAR : 1999
    MAKE : ISUZU
    MODEL : VEHICROSS
    Make : ISUZU Model : VEHICROSS Year : 1999
    Service Bulletin Num : 0305S001 Date of Bulletin: MAY 01, 2003
    NHTSA Item Number: 10001770
    Component: POWER TRAIN:AUTOMATIC TRANSMISSION
    Summary:
    TRANSMISSION INDICATOR LIGHT MAY BE ON AND DIAGNOSTIC TROUBLE CODE P1870 IS SET IN THE POWERTRAIN CONTROL MODULE (PCM). *TT
    Summary:
    Service Bulletin Num : 0205S003 Date of Bulletin: DEC 01, 2002
    NHTSA Item Number: 10000816
    Summary:
    TRANSMISSION INDICATOR LIGHT MAY BE ON AND DIAGNOSTIC TROUBLE CODE P1870 IS SET IN THE PCM (POWERTRAIN CONTROL MODULE). *TT
    Summary:
    Service Bulletin Num : SB0002S002 Date of Bulletin: MAR 01, 2000
    NHTSA Item Number: 612593
    Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM
    Summary:
    SERVICE INFORMATION REGARDING ALL AFFECTED VEHICLES WITH THE P1441 EVAPORATIVE EMISSION CODE THAT HAS BEEN DIAGNOSED WITH NO FAULT FOUND FROM THE APPROPRIATE FLOW CHART IN THE DRIVEABILITY AND EMISSIONS MANUAL. *TT
    Component: OTHER
    Summary:
    Summary:
    Service Bulletin Num : SB0014S001 Date of Bulletin: FEB 01, 2000
    NHTSA Item Number: 614146
    Component: SEATS
    Summary:
    AMERICAN ISUZU MOTORS INC. IS PLEASED TO ANNOUNCE THE AVAILABILITY OF TOP TETHER CHILD RESTRAINT SEAT ANCHOR BRACKET KITS FOR CERTAIN ISUZU SPORT UTILITY VEHICLES. THE USE OF THIS ANCHOR BRACKET MAY BE NECESSARY WHEN INSTALLING CERTAIN CHILD SEATS, WHICH REQUIRE ANCHORING TO THE VEHICLE WITH A TOP TETHER STRAP. *TT
    Service Bulletin Num : SB9911S003 Date of Bulletin: NOV 01, 1999
    NHTSA Item Number: 6088693
    Component: STRUCTURE:BODY:TAILGATE
    Summary:
    CONCERNS WITH TAILGATE CHECK ARM EMITTING A SQUEAKING SOUND. *TT
    Service Bulletin Num : SB9913S002 Date of Bulletin: MAY 01, 1999
    NHTSA Item Number: 605856
    Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC.
    Summary:
    INFORMATION REGARDING AM RADIO RECEPTION. *TT
    Service Bulletin Num : SB9914S006 Date of Bulletin: APR 01, 1999
    NHTSA Item Number: 606005
    Component: OTHER
    Summary:
    INFORMATION REGARDING THE VEHICROSS (VX) TECHNICAL FEEDBACK REPORT. *TT
    Service Bulletin Num : SB9914S007 Date of Bulletin: APR 01, 1999
    NHTSA Item Number: 606029
    Component: SEATS
    Summary:
    INFORMATION REGARDING THE AVAILABILITY OF THE CHILD SEAT TETHER ANCHOR KIT. *TT
    Service Bulletin Num : SB9914S002 Date of Bulletin: FEB 01, 1999
    NHTSA Item Number: 604740
    Component: OTHER
    Summary:
    INFORMATION ON PRE-DELIVERY INSPECTION (PDI). *TT
    Assimilate this .........
    Mar 2004
    A-2004
    I Found this on the NHTSA site and couldn't find a complete list of TSBs using the search function. I thought this would be a good idea to keep around. 1999-2001 are listed.
    Nothing new from the looks of it. I am aware of these, or is there something new???!
    face the mirror
    2000 Dragon Green VX 0485
    Thanks for posting the info.
    Bob F
    '99 Ebony VX #0038
    Component: SEATS
    Summary:
    Has anyone actually installed this kit? I'm assuming that it's for the "LATCH" style car seats. Is it worth getting and if so, where would I get it from? St. Charles Isuzu?
    Past Owner
    remote starter TSB
    Has anyone had any problems after installing a remote starter?
    '99 Ebony VX #0038
    I've got a remote start on mine. It's a part of my Viper alarm system. Never had any problems, except maybe twice in 5 years it didn't start the first time. It turned over briefly, cut off, then fired right up (the auto start will attempt to start the vehicle three times before quitting). Not sure why it didn't start those couple of times, but as you can see, I'm not too concerned about it.
    '99 SC Ebony #1961
    I had a problem about 2 years ago with my remote starter... the motor would not shut off after I removed the key and I ended up needing a new starter.... Been using the remote stater all time still never had another problem.
  1. Some Isuzu Service Bulletins for the VX
    By deermagnet in forum VX Troubleshooting...
    Last Post: 08/14/2015, 01:18 PM
  2. Some more Isuzu Service Bulletins added
    Last Post: 12/09/2009, 03:05 PM
  3. VX recalls and service bulletins
    By Triathlete in forum General Tips...
    Last Post: 02/16/2008, 07:42 PM
  4. Replies: 1
    Last Post: 07/03/2007, 06:31 AM
  5. Technical info
    By Doc4h in forum VX Modifications...
    Last Post: 02/19/2003, 12:26 AM
