Could somebody please check to see if your engine cooling fan is centered within the shroud - or is it offset so that there's less clearance on the left than on the right? Thanks.
If looking from the front the fan is off to the right about 3/4" off center.
So it's supposed to be off-center like that? I wonder why? It seems like they would want equal clearance on both sides...
BTW - thanks for checking on that!
