Results 1 to 4 of 4
Thread: What is this thing and does it affect my window?
    99 white ironman
    Just ordered a replacement window switch to fix a problem and apparently this had nothing to do with my window not working. I tried switching all the relays that are located under the bottom left kick-panel on the driver's side but still no function. With each switch, I tested my passenger window and it worked every time when I used the passenger's side switch. However, the driver’s side control would operates the passenger-side window, failing only when I tried to move the driver-side door down. It also never made the driver’s side window move or even make a noise. I did find this little, foam-rapped plug that only looks to have 13 and a U on it and the wires leading to it come straight from the window control unit of the driver’s side. Could there actually be relays’ on the passenger’s side that control the window operations? I have no clue what to do next. Here is a picture of the unplugged mystery piece.
    May 2004
    2001 Ebony VX, 1190
    looks like the speaker wire connector for the stock speaker...
    99 white ironman
    nevermind.. it's actually some sort of relay for the power locks that control the passenger side from the driver side door... thanks though.
    Jul 2002
    99 Ironman
    Frank, I sent you an email about upstate NY . Did you ever get it?
  1. Finally did my window mod thing
    By Bob Barker in forum VX Modifications...
    Last Post: 03/24/2013, 07:43 PM
  2. Odd Thing
    By VXR in forum Chit-Chat ...
    Last Post: 08/23/2010, 04:24 PM
  3. Replies: 4
    Last Post: 09/19/2008, 02:25 PM
  4. Odd thing....
    Last Post: 07/02/2004, 04:04 PM
  5. New tires affect on the TOD system
    By Arachnid J in forum VX Troubleshooting...
    Last Post: 09/10/2003, 08:37 PM
