Results 1 to 5 of 5
Thread: light switch problems
    98 mica yellow 0086
    When I drive at night and I hit a rough spot in the road, my light switches to highbeam...
    This is the second time I had this problem, they changed the light switch the first time, thinking that would solve the problem....but unfortunately it happend again.
    When it switches to high beam, I often can't get it back into low beam...but just hangs between... not high, not low, but the indicator on dash, indicates that high is still switched on.
    Anybody has an idea, and could it be connected to my mysterious playing cd player, even after I turned of the engine and took the key out of the ignition?
    Help
    98 mica yellow 0086
    Mmm wrong board to ask I see...anybody knows the url for "excorcists worldwide"
    What is plugged into the cigarette lighter? An item like a cell phone could be feeding voltage back into the system - has happened before.
    Do you have an aftermarket alarm? My DEI (and others) allowed me to keep the AC blower and radio playing after I shut off the vehicle until I opened the door.
    The headlight problem sounds like the switch again....
    98 mica yellow 0086
    Thanks Tone, yeah I've got a telephone charger connected...
    What are the changes though to have a broken light switch twice within one year....? Bad luck I guess, and it seems I'm the only one on this board ;eekg; ;eekr; ;eekr;
    could also be a loose connection in the relay.(happened to me once)
  1. Rear hatch dome light switch
    By H3_VX in forum VX Troubleshooting...
    Last Post: 12/02/2015, 01:16 PM
  2. Manual Interior Dome Light Switch
    By ALC1717 in forum VX Modifications...
    Last Post: 11/06/2011, 09:38 AM
  3. Isuzu Fog Light switch issues please help :)
    By LittleBeast in forum VX Troubleshooting...
    Last Post: 12/01/2010, 09:24 AM
  4. Fog Light Switch
    Last Post: 03/19/2006, 07:15 AM
  5. po122, throttle position switch, engine light on
    By sean_grigoros in forum VX Troubleshooting...
    Last Post: 10/11/2005, 10:25 AM
