james ?
james ?
1COOLVX
james , i have sent you a few messages and have not heard back from you.if you did not get these messages let me know.i see you use hotmail and that could be the problem.make sure my messages are not going to your junk mail.or not getting blocked.please email me. shawn
Hey shawn
I havent got your msgs.
I will call you later this eve
james, i just sent you a PM . shawn
james, did fedex drop the package of yet? you will need to cut a 8 1/2 " hole using the circle you can see on the back of the cover as the center.also,the top of the cover were it looks like a half moon and dents in toward the tire, remove the ribs that stick out with a razor blade.and on the cover ,the notches on the back line up with the top rib on the door. any questions call me. shawn
hey Shawn
Not yet, tomorrow.
What did you cut the hole with blade ?
james, i used a rotozip with the circle cutter.if you want to ship it to me i will cut it for you at no charge. shawn
james did you install yet?
is there anyone else intrested the 8" rear door sub box? i will be taking orders. $325 plus shipping.figure on 25 lbs from 12814 zip code. shawn
