Results 1 to 7 of 7
Thread: TSB and check transmission light
    Sep 2004
    99 kaiser silver vehicross
    Does anyone have the text for this technical service bulletin?
    Office of Defects Investigation
    Technical Service Bulletins - Search Results
    Report Date : October 5, 2004 at 01:42 AM
    TYPE : VEHICLE
    YEAR : 1999
    MAKE : ISUZU
    MODEL : VEHICROSS
    Make : ISUZU Model : VEHICROSS Year : 1999
    Service Bulletin Num : 0305S001 Date of Bulletin: MAY 01, 2003
    NHTSA Item Number: 10001770
    Component: POWER TRAIN:AUTOMATIC TRANSMISSION
    Summary:
    TRANSMISSION INDICATOR LIGHT MAY BE ON AND DIAGNOSTIC TROUBLE CODE P1870 IS SET IN THE POWERTRAIN CONTROL MODULE (PCM). *TT
    My check trans light came on yesterday and after checking the codes I have a P1870 trouble code. Am i doomed to spend a fortune on a tranmission rebuild? If anyone has had the same trouble, please let me know. What was the fix?
    Jan 2004
    2000 Black Trooper 3248
    Check your PM inbox.
    Nate
    '99 Ebony Black VX, 0339
    For everyone else....
    P1870
    Transmission Component Slipping
    Could be nothing more than an adjustment or even a false code. Reset and see if it reoccurs according to my mechanic at Isuzu before you freak,
    Feb 2005
    2001,proton,0519
    Trans lite & TSB
    my car just came out of Isuzu with same problem, 1870,tranny slipping. Said could be many things,but most common is ASM switch at outside rear of tranny is most common. So he started by changing that. No guarantees.325 dollars.
    Have you checked fluid levels running, warm and in "Park"?
    Sep 2004
    Unhappy VX transmission update
    To update everyone on my VX transmission troubles, I checked the fluid not long after the initial trouble code. Even took it to a transmission shop to check it, they said it wasn't a big problem now. The light went on and off 2 more times and for a month didn't do anything. About 3 weeks ago, I was driving to Tulsa, OK from here (600 miles one way). Near the OK state line on I-40 I heard a pop like a gunshot. Pulled over checked the tires and underneath, all looked OK so I thought it was a piece of road debris that a tire had kicked up. After pulling into the first Muskogee turnpike toll booth, paying my fare and start accelerating, the transmissionshifts really hard, almost chirping the tires. I decide to press on and get it checked in Tulsa, only 50 miles away. I didn't made it. A few minutes later I look out the rear view mirror and to my horror see a blue smoke trail following my VX. I pull over and look under the vehicle to see it coated with transmission fliud. I was near a bridge and wanted to pull up a bit but the VX would no longer move.
    After spending 5 days in Tulsa and getting tired of not being home, I got transportation back home. 2 weeks and $2900.00 later the VX is ready to be picked up. I am flying out this weekend to get it. At least the tranny has a warranty now. Transmission shop said that there was shrapnel inside and they believed it was a solenoid failure. The shrapnel caused the front seal to fail and the transmission was 4 quarts low due to the leak. The transmission was rebuilt and a new torque converter installed.
    What got me was that the check trans light never came on after all of the fluid loss and transmission failure. I guess it takes a lot to make it come on when it does count. Thanks to everyone for your posts.
    Apr 2003
    2000, Dragon Green, 0808
    Wow, $2,900 for a rebuild. I would almost think that you could find a used one for less, maybe not? I really need to get mine in and have the fuids/filter changed. That is a pretty scary story. Sorry to hear that.
  1. Tod Check Light Help!!!
    By ron in forum VX Troubleshooting...
    Last Post: 07/02/2007, 10:56 PM
  2. Check transmission light blinking ?
    By Andrey in forum VX Talk...
    Last Post: 01/25/2006, 11:22 AM
  3. VCross transmission check
    By JABO in forum VX Troubleshooting...
    Last Post: 10/29/2004, 09:37 PM
  4. Check Transmission light
    By nwdyver in forum VX Troubleshooting...
    Last Post: 10/27/2004, 08:38 AM
  5. Check transmission light
    By Andrey in forum VX Troubleshooting...
    Last Post: 06/27/2004, 12:26 PM
