With all the posts about oil usage I've got a question. I go thru a quart about every 1000 miles, sometimes less, sometimes more, its never consistant (there are no leaks). I replace the PCV valve on a reg basis and keep the EGR valve clean. That helps but the usage is there. I spoke with my mechanic that I've used for the last 13 years and he said at some point the engine will need replaced (well duh). I just turned over 82,000 miles and that seems a little premature to be replacing.
I check the oil every couple of weeks and add when necessary but will this usage eventually lead to total engine falure or can the engine be fixed before that happens? New rings, seals, etc? Or will I just be adding oil for the rest of the VX's life (which I don't mind) Anyone had experience with this?
Hope everyone out there has a good New Year.
