Results 1 to 11 of 11
Thread: WOW..285's fit my 18" rims??
    Oct 2003
    2001 Dragon green 0669
    Question WOW..285's fit my 18" rims??
    Yikes....got my tire delivery today and they are huge!!!!
    Nitto Terra Grapplers 285 60 18
    Will they really fit properly on my stock 2001 18" rims? ?
    They look sooooo huge next to the 245's on there now!
    With these mounted what will my speedo error be....I am guessing when I'm doing about 60mph the speedo will show 55mph?
    Also will I be driving more miles than my odometer will show?
    I will be mounting these next week if all goes well.
    Thank you to all who has helped me with your posts on this subject !
    Dave
    "MARS ATV"
    1999, Ebony Black, VX ,1976
    the specs are below for the 18" and 16" . i have the 16" on mine and they fit with minor trimming.so the height is not an issue.the width and suggested rim size may be an issue.i believe the 16" rims are 7" wide i do not know about the 18" rims. shawn
    tire size / height /width /suggested rim size
    285/60 R18 /31.38 /11.54 /8.0-(8.5)-10.0
    265/75 R16 /31.54 /10.75 /7.0-(7.5)-8.0
    1COOLVX
    Hey DocDave,
    Could not resist the bigger shoes he???
    Gotta love it!!
    With those big tirese you should get some deviation from the speedo and odo readings...nothing to be concerned about though. If you really want to find out what the speed difference is go to the local "cop shop" and have then do a radar calibration on the VX with the new tires. That's what I did with my old Chevy Blazer and found out there was a 5 mph difference to actual reading.
    John
    2000 Dragon Green VX 0485
    Quote Originally Posted by drdavidr4u
    At 63.8 MPH speedo will show 60.0 MPH or 6.4 PERCENT SLOW
    Your new tire is 1.9 inches larger in Diameter.
    Bob F
    2001,Ebony,VehiCROSS,1092
    Hey Doc -
    Yes, they will fit - I just put Pirelli P-Zero's on, size 285/55/18, and they fit like a charm, no trimming. I love the head on and view from the rear, but I'm still not used to the side view, though. From the side you see a lot more sidewall because of the way the tires bulge out from the rims instead of going straight up like the 245's did. I always hated the view from directly behind with the stock tires - they looked puny and made the VX look cheap/sickly. I think the guy who put the tires on summed up the new look the best - "man, that thing's a little beast!"
    The 285's come out close to the edge of the cladding and look like they belong! With the 285/55 (as oppossed to 60's) you get very little height difference, so little speedo inaccuracy, and NO TRIMMING of the cladding needed! you'll love the look when you get them on!
    '01 Proton 1416
    tire calc site
    I used this site, it's really easy.
    http://www.miata.net/garage/tirecalc.html
    Brian
    '01 Proton 1416
    '99 Astral Silver #1321
    Do not depend on the online tire calculators. With 265/70-16 BFG ATs my speedo was supposed to be just 4% slow according to the calculator. Laser said different. I got a GPS and it agreed with the cop's laser.
    Rick "Baxman" LaMarche
    also ,the tire calculator shows a different size than the actual tire size. it shows the tire at 31.5 " and the height is really 31.38 " .so the speed is off from what it tells you. and there is also the amount that the speedo could have been from the factory. the only way to know for sure is radar or gps. shawn
    Jul 2002
    99 Ironman
    wow Dave must look great, see them at the next vx meet,, post pics !!
    That is the same size tire I ran on my stock 18", Pirelli Scorpion Zeros, great fit!
    Quote Originally Posted by Baxman
    Hey Bax... good to see you are still around, by the way! You don't post as often as you use to!
  1. 16 " Inch rims
    By VX FIX in forum Miscellaneous Items For Sale
    Last Post: 01/30/2017, 07:45 PM
  2. Need advice on these 18" rims
    By TonyVX in forum VX Talk...
    Last Post: 06/05/2016, 07:00 AM
  3. Tires for 16" Rims
    By dietz99vcross in forum VX Talk...
    Last Post: 02/04/2008, 10:41 AM
  4. After market rims 20"
    By sam in forum VX Modifications...
    Last Post: 10/31/2005, 03:32 PM
  5. 18" Rims & Tires: FS
    By Child's Play in forum VX Talk...
    Last Post: 01/12/2005, 08:18 PM
