Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: repack bearings
  1. #16
    '99 Ebony VX #0038
    ...Once you have removed the Superwinch hubs (or hub covers for those of you who do not have manual hubs), take a rag and wipe away any grease that you see on the end of the axle shaft...
    ...Install the gaskets for the "hub/bearing cover/hub flange" (I used RTV silicone/gasket maker). Reinstall the "hub/bearing cover/hub flange"...
    My interpretation is that the Superwinch hubs as well as the stock hub covers are sealed with a gasket. Apparently he couldn't find the part either because he used RTV instead.
    Let us know how this job works out for you and any tips you have. I need to do mine very soon also!
  2. #17
    Feb 2004
    2001 Ironman #1109
    We don't need no stinkin' gaskets
    That gasket referred to in the planetisuzu post is not a part we have - I think its for the superwinch hubs only.
    My neighbor was recently kind enough to lend his garage and a set of helping hands to do this. It took about 3 hours total and was easy as pie. We used about 1/2 of a tube of grease.
    thebear54 was right - hand packed is the way to go. Put some grease in your open palm, and hold the bearing ring in your other hand. Push the outer face of the ring into the grease blob in your hand, and repeat until the grease is forced all the way through, coming out the inner face of the ring. Rotate the ring a little in your hand, and repeat, until you have gone all the way around the ring. I then went around again two more times just to be sure.
    Good Luck!
    Ron
  3. #18
    May 2003
    Wink
    Thanks for the tips guys!
  4. #19
    2001, Kaiser Silver, #988
    This may be a silly question/comment, but I had an Isuzu dealer perform the repack. I walked in with a can-like container of Mobil 1 grease and the service tech only used about a handful of it, didn't seem like much at all and there was over 3/4's of grease leftover.
    In fact he asked me what else he could use the grease for and that there were no other spots under the VX that he could lube or grease, at all.
    Does this seem right??
  5. #20
    2000, Black, VX, 0021
    Seems right to me. The bearings don't really have much space between the races and bearing cage to hold much grease. However the hubs seem to be where the grease goes over time. Still, having repacked a lot of Toyota hubs, it does not take much grease.
    I have yet to do my VX but they are way over due and will be done this spring if I get off my arse.
    Anthony
  6. #21
    May 2003
    Smile
    Quote Originally Posted by kpaske
    I did mine at 45,000 miles (should've been done at 30,000 miles...dope!) and I just finished the job...started 9 A.M. Saturday morning and was done with tools put away and myself cleaned up by 2:00 P.M. This also included taking my disc brake sliders apart to clean and regrease with silicon grease and spraying various front-end components with Silicon Spray to keep the rubber pliable (C.V. Boots; Tie-rod end rubber seals; etc...). I also pulled the rear brake slider pins out...wiped them down...and regreased with silicon grease. I live on a dirt road and dust gets into everything!
    Only tips I can add to the excellent tutorial posted in this thread is that you really should invest in an impact(the kind you hit with a hammer) with #2 Phillips bit and also use it with an 8mm Hex bit. I bought one from Advance Auto for $19.95 with #2 Phillips bit included and purchased the 8mm hex bit separately for $3.95. The impact with #2 Phillips loosened the trouble prone (3) 4X8mm screws so nicely that I reused them even though I had new ones because they were still in perfect condition! The impact with 8mm hex bit broke loose the six allen-screws spanning the circumference of the hub and then ratcheting them off with said bit is a snap! Don't forget that you need the wheel/tire on without centercaps in order to break the 6 bolts loose. (This meant I had to remove wheel/tire...take out chrome centercap...replace wheel/tire with 2 opposite lugs...break loose (6) 8mm bolts...remove wheel/tire!)
    Be careful after removing the snap ring to remove the small washer that is behind it and is the same size as the snap ring....as this washer is not mentioned in the tutuorial and is very hard to see with grease covering it!
    I thought the seal puller tool from Advance was worth $6.96 but since I live far from a Pep Boys I didn't have the benefit of a seal driver and couldn't find it anywhere else...so just used a block of wood (soft pine) and a rubber mallet and it seemed to do the trick.
    I needed 5 small cans of carb spray from Walmart as 4 was not quite enough.
    I used 2/3-3/4 can of Valvoline Synthetic Grease from Advance $4.89...most of the grease is used building your Grease dam in the hub between the races. RTV'ed the Hub flange(no gaskets were on mine) and also the hub cover (dust cover?) as I could see evidence (light rust) of water slightly getting into hub cover.
    Cleaning out old grease from parts and setting the preload probably were the biggest time killers for me...I finally got the Preload set at 3# forward & reverse....was shooting for 3.3#! It danced all around 2 to 4 until I finally got it to read about 3# or a tick better!!!!
  7. #22
    Impact wrench that you hit with a hammer might be good for those little phillips as the heads strip easily. In lieu of that, take the correct sized phillips screwdriver and hit it with a large hammer a couple of times and they will come right out easily. I just did bearings on 2 VXes it worked like a charm.
    The IS a relatively large area between the front and rear bearings that should be packed with grease and the rest would be used to pack the bearings unyil it flows through the rollers (IF the dealer did it right - if they only took them outn didn't clean them, and put them back in, you'd only use half a can).
    Seal puller is really only needed if you are trying to reuse the seals (which are only $4 ea). A screw driver or pry bar can easily pop them out without damaging the hub.
  1. Rear Rotor Replacement require hub/bearing repack like fronts?
    Last Post: 01/25/2012, 08:51 PM
  2. Replace seals when repack bearings?
    By LiquidVX in forum VX Talk...
    Last Post: 05/08/2010, 10:38 AM
  3. Repack Front Wheel Bearings
    By DK in forum VX Troubleshooting...
    Last Post: 03/06/2008, 01:20 PM
  4. Bearing repack/ rotor replacement write up
    By MSHardeman in forum VX Modifications...
    Last Post: 09/27/2007, 09:26 AM
  5. Bearing Repack help
    Last Post: 11/17/2004, 01:31 PM
