Results 1 to 3 of 3
Thread: Finally!!
    Finally!!
    been wanting to do this stuff for a long time, finally got to most of it..still have a few things left, but heres what ive done so far:
    finally got the piaa fogs wired in , ended up having to replace a brand new relay (grrr) , and i cut the piaa switch into the spare block out plate by the hazard button..still needs some finishing, but not bad..
    I installed turning lights in the side larker side housings. I used parking light sockets i found at the salvage yard some time ago (isuzu even!) , drilled out the holes, notched them with my dremel and bingo, factory looking fit.
    I installed one super hi output white LED
    (with resistor) in each of the front lower turn signal housings,wired up to the parking lights. it gives them a cool amber glow. More than bright enough to do the job.
    shows where i installed the led, there was already a chanel there, not sure what the original purpose of this was, but i used it..
    soldiered the ground right to the directional light housing:
    fogs, and leds (directionals on side markers didnt photgraph well: )
    Maverick
    99' Ebony VX sold...
    Cool, maybe I will get to see it in person real soon.
    The Bantan's Relm
    Gallery
    Myspace Page
    those little super bright led's are awesome, awhile back i imported a box of them in white, red, and green..the white ones i put in the directional lights as marker lights , show allot brighter than i expected. i only put one in each side, and its nearly as bright as the the incandescant light bulb, gives it a shimery type glow. if i put three more in each one it would be extremely bright!
    im going to use a few for the interior. ive already got a green one inset into the overhead console, which will be wired to the dash lights and project a soft glow onto the shift console itself, bently does this and its a really cool effect..not distracting at all (though they use a red one.)i think ill also put one in each footwell , and maybe a set in the back so when the rear door is opened they come on, theyre so small theyre easy to put just about anywhere...
  1. Well I finally did it!
    By Polie in forum Chit-Chat ...
    Last Post: 04/05/2012, 02:09 PM
  2. Finally
    By twalker920 in forum VX Talk...
    Last Post: 10/08/2011, 05:11 AM
  3. he's finally gone...
    By pbkid in forum Ldub's After Midnight Topics
    Last Post: 01/29/2010, 09:12 PM
  4. Well, I finally got one!
    By alanbradley in forum VX Talk...
    Last Post: 12/09/2007, 06:32 PM
  5. Getting another VX, finally
    By goffaramma in forum VX Talk...
    Last Post: 02/20/2006, 10:13 AM
