Results 1 to 6 of 6
Thread: Brake light on
    2001,Ebony,VehiCROSS,1092
    Brake light on
    Took my VX to the shop today for tire balance, when I got it back the brake light is on. It seems to be in the emergency brake sensor, if you pull the handle up slightly (not to the first ratchet) the light goes out. Of course, as soon as you let go of the handle, it comes back on. I assume there is a dip switch down in there, but it seems odd that the light would go out when you pull UP on the handle. Anybody had this happen that can shed some light before I tear into the console?
    If you are interested the parking brake switch is located directly on the bottom portion of the lever in the center consule. It will not take too much ripping and tearing to get at it. I just checked my VX troubleshooting book and it's not too bad to get to and change if you have to.
    John
    99 white ironman
    Looking for help: my brake light illuminates whenever I hit a bump and then eventually goes out after time. Ther is brake fluid in the res and I don't think it's the e-brake switch. Any ideas.. thanks
    Feb 2003
    2001, Black, VX, 0781
    I had a problem where the dual filaments in one of the L/R brake light bulbs were shorting which caused the 3rd brake light to illuminate at odd times. Easy enough to test for by removing each bulb individually and seeing how that affects behaviour - if you can get someone to watch the lights for you.
    Oct 2004
    99 Astral VX 1032
    Currently my brake light has come on during the winter, but then goes away after everything heats up, about a half hour of driving. The resevior is just a hair low, so I know why the light is on, there is a lack of fluid, until it heats up, expands and just passes the sensor. Anyway, that is my theory and I am sticking to it until I add more fluid after I put stainless steel lines on.
    Ryan Christiansen
    Trooper Skid Plates, OME 912's, Stric9 Sliders, Load Warrior with extension, Apline sub in rear door, Apline front speakers, Alpine head unit, Definity Dakota MT 285/75 R16, Aussie Lockers Front and Rear, 4.77 gears and Warn Manual Hubs.http://picasaweb.google.com/RyanVehiX
    Aug 2005
    2001, Black, 1269
    LED Brake Lights
    I had the LED brake lights replacing the original 1157s. after a few weeks the 3rd brake light came on dim and stayed on. I didnt notice until it failed inspection for it. The post above pointed me in the correct direction right away!
    Thanks
    Damon
  1. Brake Light Modulator
    By Breezy in forum VX Modifications...
    Last Post: 10/25/2011, 04:32 PM
  2. Brake Light
    Last Post: 11/22/2009, 04:05 PM
  3. Brake light on at startup
    By videoboy in forum VX Troubleshooting...
    Last Post: 09/15/2006, 07:12 AM
  4. Emergency Brake Light...
    By Cyrk in forum VX Troubleshooting...
    Last Post: 03/08/2005, 08:32 AM
  5. BRAKE Light on while driving
    By tomcat837 in forum VX Talk...
    Last Post: 06/17/2004, 01:10 PM
