Results 1 to 4 of 4
Thread: Engine won,t start...HELP
    Question Engine won,t start...HELP
    Wife took the VX this morning. It started right up...no problem. Stopped at gas station to fill it up. Turn key. All lights, bells, and whisles work. Starter does not turn. No clicking...nothing. Any ideas? Thanks!
    '99 Ironman, 0992
    It is most likely the switch on the shifter that makes sure transmission is in park. Try turning the key on and holding the brake down and running it through the gears and back to park. If this fixes it it may be slightly out of adjustment. If not it may be deeper in the electrical system or a bad switch and require a trip to the dealer.
    2000,black,029
    Is the theft light blinking like it normally does? Could be something with the theft system.
    Andy from Isuzu America
    Jay and Andy,
    Thanks for the responses. Found my problem. Previous owner had something aftermarket installed which was removed prior to my purchase. Anyway they had spliced the power wire under the dash and the wife kicked it loose. Respliced...good as new!
  1. new engine start up?
    Last Post: 06/30/2013, 07:55 PM
  2. newly installed engine won't start
    Last Post: 12/18/2012, 08:03 PM
  3. Engine Rolls Over, Won't Start
    By ShadowRider in forum VX Troubleshooting...
    Last Post: 03/02/2009, 05:30 PM
  4. Engine Start button install walkthrough
    By Yefim in forum VX Modifications...
    Last Post: 11/12/2002, 10:59 AM
  5. Replies: 2
    Last Post: 11/09/2002, 12:50 PM
