Results 1 to 6 of 6
Thread: Fault Codes?
    2001, Ebony Black, 1153
    Question Fault Codes?
    So my check engine light has been on since I bought the car on December 2nd. When I tried to get it inspected in Houston it failed because:
    Fault Codes:
    P0440: Evaporative Emission Control System Malfunction
    P0405: Exhauast Gas Recirculation Sensor A Circuit Low
    What does this mean and what should I do? I do have the PV Muffler (it was on there when I bought it). Thanks in advance, Ryan. Oh yeah I drove outside the city to Waller, TX(middle o' no where) to get it inspected and it passed with flying colors even with my cracked belt that I need to replace!
    May 2003
    '99 Astral #1613
    Hopefully you just need to clean out the build-up in the EGR (Exhaust Gas Recirculation) tube. Use this site's search feature for posts on how to do this - I think someone even posted pics too. It's something I've been meaning to do myself as well but just haven't yet. If that's all it is, it should be a fairly easy and very cheap fix - nothing to get too worried over. But if it's the EGR valve itself, I think it runs around $150. Or maybe a bad ground.
    EDIT: see here: http://vehicross.info/forums/showthr...clean+egr+tube
    Look, yet another post on codes - is search NOT working?
    Thanked: 7
    LittleBeast, Doing a search on the code numbers bring back a lot of information. Here is but one of the threads on the 440:
    440
    Anita
    2000 Ebony #263
    AnitaProtich.com
    Quote Originally Posted by Heraclid
    $120 and change here. Thought I'd throw that in.
    Don Viner
    Sunset Isuzu
    6211 L Street
    Omaha, NE 68117
    O - (402) 733-2227 ext 214
    F - (402) 733-0395
    M - (402) 505-2147
    don@sunsetisuzu.com
    http://www.sunsetmotors.net
    1999, Ebony Black, VX ,1976
    Thumbs down
    TONE , Why must you be so sarcastic ??? If you look he has been a member for a maybe a month.Give the guy a break. :frownr: :frownr: :frownr: :frownr:
    Shawn
    1COOLVX
  1. TOD CODES, 14 and 24
    Last Post: 07/12/2012, 08:15 PM
  2. Need Help TOD & ABS codes
    By Scoobymlr in forum VX Troubleshooting...
    Last Post: 06/19/2012, 08:22 AM
  3. Fault Code 131
    By FuddyMucker in forum VX Troubleshooting...
    Last Post: 02/08/2010, 03:44 AM
  4. Replies: 7
    Last Post: 08/03/2007, 05:33 AM
  5. fault code
    By patrick cooper in forum VX Troubleshooting...
    Last Post: 09/27/2006, 01:18 PM
