Results 1 to 7 of 7
Thread: adjusting the valve clearance.
    99,ebony,vehicross0229
    Hey tone. i hope this message gets to you. I currently live in san diego
    california. I recently took my vx to an Isuzu dealership servicing center
    to have some scheduled maintainance done via ownersmanual says every
    60,000 miles adjust valve clearance. I don't know how to do the work myself and i can't find a hayes, or chiltons manual. But, anyway their trying to tell me that it's a deep engine knock,and their also trying to say i need a new engine that will run me 7300.00 sum dollars. I think it may be the lifter. the chattering is coming from the upper left. what do you think it may be, and do you know any place i can go to get this fixed, and fixed right.
    Valves should be adjusted at 60K but I have never done it and the Workshop CD does not describe it. A deep engine knock is bad and may indeed indicate a failing engine (spun rod bearing is most often the cause) and should run more like $5K. If it is indeed upper engine, any certified shop should be able to diagnose and repair properly.
    I will be in LA Mar 2-5th if you would like me to take a look at it.
    BTW, my email address is visible if anyone ever wants to contact me directly...
    There's a couple different places that the valve clearance adjustment procedure might be found. I'll take a looksee through the full tech library tomorrow if I get a chance.
    Don Viner
    Sunset Isuzu
    6211 L Street
    Omaha, NE 68117
    O - (402) 733-2227 ext 214
    F - (402) 733-0395
    M - (402) 505-2147
    don@sunsetisuzu.com
    http://www.sunsetmotors.net
    1999,silver,vehicross,1891
    How much should a valve adjustment job cost? I have 106K miles, I doubt they were ever adjusted, my millage performance is lower than spec but the engine runs strong, it's a mean Vehicross, and I love it. The gasket kit with gromets and spark plugs seals are about $70 online, about half factory or autozone type pricing; how much should labor cost for this job? How much does Isuzu dealer charge? Anybody know? THANKS!! Erik
    '99
    This is an Isuzu tech video on adjusting the valves on our engine. It's small and a bit rough, but you'll get the idea.
    7:11, 14.1 mb, 320x240, wmv file-
    http://www.drivehq.com/file/df.aspx/publish/mgpa/techvids/valvadj.wmv
    Mark
    Quote Originally Posted by deermagnet View Post
    Mark
    Mark, I don't know where you come up with these vids (is that you in the starring role? ), but they are of tremendous value to this community & I would just like to say Thank You!
    Also, I'd like to ask Moncha to include this one in the "how to" section along with the timing belt trilogy.
    The link to that video doesn't work anymore. Where'd it go? I need it.
  1. Weird Tire clearance HELP!!!
    By gonzo7231 in forum VX Modifications...
    Last Post: 10/25/2013, 03:43 PM
  2. Adjusting Your Vehicle's Side-View Mirror For Safety
    By tom4bren in forum General Tips...
    Last Post: 01/25/2008, 09:39 AM
  3. where is PCV valve located, and how do i clean the valve tube?
    By CoastieCosta567 in forum General Tips...
    Last Post: 05/14/2007, 09:33 AM
  4. recall clearance
    By jacobus in forum VX Talk...
    Last Post: 09/28/2005, 01:25 PM
  5. re: Bump Stop Clearance
    By ameetw in forum VX Talk...
    Last Post: 01/15/2004, 06:10 PM
