Results 1 to 6 of 6
Thread: Fuel Injector Size
    2000,silver,vehicross,0460
    Fuel Injector Size
    What size fuel injectors are stock on the VX? Flow rate?
    19lb - more than enough for even the SuperCharged ones - now if someone can just crack that ECm and alter the pulse....
    I talked to a unichip dealer in Illinois. The chip installation (which could be a pain because of no specific unichip plug N play) and tuning could run to $ 2000. As is now with the supercharger, tuning could produce a 20 to 40 HP gain, though . . .
    http://www.grdperformance.com/
    Realize we are already at the transmission's limit of power handling - more could cause problems....
    I've read in at least one place that the ECU was a GM unit (slightly modified of course). Has anyone else heard this?
    It is a gm based unit but the LS1 edit will not work on our units. I am still working on finding someone or some thing that will since i will be giving my motor a little more boost than the Alpine kit does.
    Drive it like ya stole it!!!
    2002 Axiom XS
    -20" Eco 820s with Goodyears
  1. Here is another pictorial, mushed injector O rings
    By Ebenezr in forum VX Troubleshooting...
    Last Post: 09/07/2011, 06:31 AM
  2. Help/Hints - Replacing Injector O-Rings
    By Techy-D in forum VX Talk...
    Last Post: 06/01/2007, 09:16 AM
  3. Fuel Injector Question...
    Last Post: 05/11/2005, 02:23 PM
  4. fuel injector cleaner
    By UtahVXer in forum VX Talk...
    Last Post: 03/17/2005, 07:58 AM
  5. hard to start..leaking injector?
    By autox-racer in forum VX Troubleshooting...
    Last Post: 09/22/2004, 10:30 AM
