Results 1 to 5 of 5
Thread: window wont close all the way
    01 Proton VX.0851
    the passanger side window will not close all the way up. All I hear is a clicking sound when I try to get it to close (all I need is about 1 inch more) What do I do! SOS.. its raining here in new york, please asap, thx BRUCE
    May 2002
    2000, Proton Yellow, VX, 0584
    Did you grab the front edge of the window as it was going up to assist?
    Don't forget This
    Scott / moncha.com
    Dec 2004
    2000, GREEN, UT,0782
    Quote Originally Posted by Sheik-YurBooty
    Sounds like you're another victim of the Dreaded Window Failure. First thing you should do is file a complaint on line (check the poll section). Second, I have has some small success by squirting large quantities of silicone lub into the window tracks. My driver's side window completely failed and I had to have it repaired. Then, a couple of weeks ago, the passenger's side window began to jam a half inch or so from full closed. The silicone has, at least temporarily, fixed that problem and the window is closing all the way.
    I'd give it a try before doing anything else. It's a cheap fix if it works.
    Do as Moncha said. Hold the front part of the window and pull up and back as you close the window. This will keep it on track and allow it to close. Just make sure to get your fingers out of the way so you don't lose 'em!
    And then fill out the online complaint!
    Thanked: 7
    Arrow
    Hopefully you have not broken the plastic tab that is affixed to the bottom of the glass. What you describe is similar to what happened to me in that as the window took more and more effort to close and it began to get off the track, I eventually broke the tab in continuing to use the window. If that happens... a new glass may be needed, as well as a regulator if it goes bad.
    Anita
    2000 Ebony #263
    AnitaProtich.com
  1. wont start
    By evillecutter in forum VX Troubleshooting...
    Last Post: 11/03/2012, 07:56 AM
  2. Wont shift out of park!
    Last Post: 02/02/2012, 07:05 AM
  3. My tire wont hold air..
    By dtruax in forum VX Troubleshooting...
    Last Post: 05/04/2009, 12:48 PM
  4. wont start without remote
    Last Post: 07/30/2008, 04:25 AM
  5. HELP! My VX wont come out of park.
    By smorris65 in forum VX Talk...
    Last Post: 04/11/2007, 04:28 PM
