Results 1 to 2 of 2
Thread: Running with the spare tire question
    NC 1999, ironman, 0358
    Question Running with the spare tire question
    What happens if you use a spare tire (I'm not near the VX now to go check, and am thinking the stock spare is smaller diameter) that is smaller diameter than the other tire on the front? Would this cause damage? I suppose that with a locker this would be a big no-no; but what about the stock running gear? And, if this is a bad situation, maybe this would be a good reason to have a TOD disconnect switch?
    Western North Carolina...
    Veni, Vidi, Velcro
    Thanked: 7
    Arrow
    The spare donut should always be used on a front wheel. So if you have a flat on a rear tire you will need to move a front wheel back and put the spare on the front. Definitely go slow and limit the number of miles you ride with the spare on.
    Auto-racer just had an experience with a flat and he posted this info:
    "I did learn a few tricks when it comes to driving with the spare and TOD. Left foot brake when you come up to a light with light throttle. Otherwise the TOD makes a nasty noise as it downshifts. Also drive slow as the instructions say... Otherwise the Tod senses road speed differences and starts to engage/disengage 100% and makes a very nasty grinding noise. I found I could stop this with left foot braking again... Just step on brake while still on gas to disengage TOD".
    I dont think it is only the TOD that is affected - was there something concerning the differential that causes a bigger problem (?)
    Anita
    2000 Ebony #263
    AnitaProtich.com
  1. Use of spare place of spare tire...
    By uncle_asa in forum General Tips...
    Last Post: 08/10/2009, 11:31 AM
  2. Spare tire vs Tire Sealer?
    By Petos in forum VX Talk...
    Last Post: 04/25/2008, 08:02 AM
  3. Flat tire - spare size question
    By Anita in forum VX Troubleshooting...
    Last Post: 08/29/2007, 09:07 AM
  4. Spare tire question ???
    By psychos2 in forum VX Talk...
    Last Post: 05/02/2007, 07:59 AM
  5. Spare Tire
    By ScubaSteve in forum VX Talk...
    Last Post: 01/15/2004, 01:18 PM
