Results 1 to 4 of 4
Thread: Center Bore Drilling?
    Apr 2003
    2001 Grey VX 0867
    Just wondering if anybody out there has had to drill a larger center bore in order to get their new wheels to fit correctly. Does this change the integrity of the wheel dramatically? Any info, much appreciated.
    Nov 2002
    Arrow
    I had to relieve the center bore on the Nissan Frontier wheels I got for rally, but I used a die-grinder for that and just removed a little material. It depends a great deal on the wheel though. Your best bet is to take them to your local machine shop and let them advise you and also perform the work. This is a very simple procedure for any basic machine shop and should cost you less than $100 for all four wheels. Even though only the front wheels require it, you'll still want to be able to rotate your wheels if needed.
    I had to open up the bore in my new 22s, i used the machine center (mill) at the shop. Took about one hour with setup. I went from a 74mm to a 108mm and went 9mm deep. You could really weeken a wheel if you take out to much metal so be careful.
    Drive it like ya stole it!!!
    2002 Axiom XS
    -20" Eco 820s with Goodyears
    Just make sure you take the metal off all the sides fairly evenly so that tightening your lug nuts centers your wheel. If the hole through the wheel binds on the hub while tightening it, your wheel will be running off center. If I remember right Our hubs are 99mm.
    Its the thrill of the chase
  1. need advice- our center bore is not 108mm
    By djvx in forum VX Talk...
    Last Post: 12/17/2010, 10:00 AM
  2. Center bore and wheel questions.......
    Last Post: 12/11/2010, 03:18 PM
  3. Custome Center Bore ?
    By tjh in forum VX Modifications...
    Last Post: 02/06/2010, 07:03 AM
  4. will these rims work/bore size
    Last Post: 09/02/2009, 11:06 PM
  5. Front wheel center bore
    By Bimati in forum VX Troubleshooting...
    Last Post: 07/30/2006, 06:22 PM
