Results 1 to 15 of 29
Thread: Need sound advice on TIRE UPGRADE!
    Aug 2004
    01, Kaiser Silver, VX, 1102
    ok, my 01 VX is in need of some new soles on its shoes, only got 25K on her but need to know widest stance, and tallest tire I can use on my stock OEM 18 inch rims, which I hate by the way ****ing chrome rims suck...I don't off road it except on beach here in Daytona so can use any insight from the masses. Thanks
    Last edited by Moncha : 05/14/2005 at 08:41 PM Reason: Language! That is considered your first warning.
    2001,Ebony,VehiCROSS,1092
    275's are the recommended max width on the stock rims, though several people (me included) are using 285's. Max height? depends on your goals - do you want the speedo to be close to accurate? If so, 285/55's are best - a lot of people have also used 60's, which are about 1" taller IIRC, with no problems.
    If you don't care about speedo accuracy/gearing, then it comes down to how much cladding trimming you want to do. Someone here with experience in that department will chime in to help, I'm sure.
    The 285/60 or 55's look like what should have been on the VX from the factory. They extend out to the edges of the wheel wells, and from the back or front give it a much sportier stance. The ride with these wider tires is rougher, and the VX tends to follow ruts in the road. While those two side effects could be related to my choice of tires (Scorpion Zero's), I've heard others mention the rut problem with other brands. Neither are a big problem IMO, and definately worth the trade-off for the much improved looks.
    Aug 2004
    Thanks for input. Don't want to trim any cladding so really want max width, and height without trimming..Thanks
    May 2004
    2001, Ebony Black, VehiCross, 0432
    I've got 275/55 R18's on and I really like them. They don't "bulge" out to much from the side of the rim and I didn't have to trim any cladding. The tires areToyo Proxes S/T's and you can find them at https://www.tiresavings.com/index.php. Just put the tire size (275/55 R18) and they will come up. Take a look at my gallery, I beleive there are a couple of pics. in there.
    Adam
    2001,silver,906
    I bought BF Goodrich long trail TA's from Tire rack this week..$58 a piece 265 60 18..( I checked Today they are still on sale) Getting them mounted tomorrow morning.. The shop I had them sent to called today, all upset, asking me if I was sure they were going to fit??I searched thru the site and read that all I have to trim is a small amount..I will try to post photos..Tony B
    2001, IronMan White, #440
    Thumbs up Yokohamas
    I just bought some new shoes. It sounds like my driving is a lot like yours. I went with Yokohama AVT 285/60/18. There was no trimming required. It's a forward aggressive looking design that seems to fit the VX perfectly. As a matter of fact, Wormgod, has a picture with them on his VX. It's labeled "Most Viewed Photo" and is 4 boxes down from the upper right corner.
    Peace.
    Oct 2003
    2001 Dragon green 0669
    Love my tire upgrade...
    Just had to chime in...
    Love my tire upgrade...went for the more agressive looking tires...nitto grapplers in 285 60 18 I believe....cost about 175/tire and was worth every penny!!!
    I love how my VX looks....most agressive thing on the road now!
    Handles great, was fine in the snow...no floating noticed....slight road noise not too bad though...WIN WIN deal!!! fills in the wheel well like it was meant to ...why they didnt put these on to begin with I'll never know!
    check out the comparison...stock vs nittos!!
    http://www.vehicross.info/gallery/sh...cat=500&page=1
    "MARS ATV"
    Feb 2004
    '01 Ebony #0830
    Mudders...
    I love my 255-70-16 GoodYear Wrangler MT/R's! They are a very agressive tire. The noise level is not bad, and the off-road ability is wonderful! Only complaint: Pavement emergency braking/maneuvers make me a little nervous. Low Traction and easy lock-up are issues. But, I'm hard headed and love the tires anyway! LOL! (Just makes me a more careful/strategic driver).
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    Aug 2004
    Nitto Grapplers advice needed..
    Seeking new shoes, noticed after housrs of searching site threads that Nitto Grapplers are the prederred tire upgrade. QUESTIONs.
    1. For my stock 18 inch 01 VX rims, will the Grappler 285/60/18 require any trimming? I do not want to trim anything on cladding.
    2. Will 285/55/18 fit with no trimming?
    3. Will 285/60/18 change speedo?
    Thanks all.....
    Last edited by Moncha : 05/06/2005 at 05:50 PM Reason: Merged your 2nd thread to this one (Same subject)..
    2001,silver,906
    I had my tires mounted today.You do not have to trim for 265-60-18..2 inches away from front cladding corner.They fill the wheel wells nice.Looks like it should have come with this size,maybe a little more offset on the wheels would look a little bit better. Total price with shipping, mounting,balancing,tire disposal,NY sales tax--$403.24 smooth ride and good looks-- Priceless Just in case they are still on sale at Tire Rack
    The 285/55's are 2.6% too slow - when the speedo reads 60, you are actually going 61.6mph. The stock tire diameter is 29.6", these are 30.3". The 285/60's are 6.4% too slow - when the speedo reads 60, you are actually going 63.8mph. These tires are 31.5" in diameter. Check this site for more info:
    http://www.miata.net/garage/tirecalc.html
    Speedometer Change
    Yep, the 285/60/18 changed my speedometer about 4.5 miles at 40 mph. Which means when my speedometer says 40 mph. I'm really traveling about 44-45 mph.
    Correct me if I'm wrong, but I think the Nitto 285/60/18s require just a bit of trimming. They are just a hair bigger than the Yokohama AVT 285/60/18s which require no trimming.
    Peace.
    May 2002
    2000, Proton Yellow, VX, 0584
    There's the Miata tire calculator and a couple of other ones listed in the Web Links Section
    Scott / moncha.com
    Quote Originally Posted by Beavertractors
    I believe these are the same tires VXCaver is running. They wear really quickly. His are close to 0 tread after only 25000 miles. They also didn't perform to well off road other than dirt roads!
    May 2002
    NOW you tell him!!
  1. Looking For Tire Pressue Advice
    Last Post: 11/18/2010, 01:13 PM
  2. Tire and wheel size advice needed
    By BritVX in forum VX Modifications...
    Last Post: 09/23/2007, 06:48 AM
  3. last minute TIRE ADVICE (for AR chambers)
    Last Post: 09/14/2007, 07:37 PM
  4. tire advice
    By misterdallas in forum VX Talk...
    Last Post: 04/12/2006, 10:30 PM
  5. Need tire advice....
    By Flyingarmy in forum VX Modifications...
    Last Post: 03/01/2005, 12:02 PM
