Results 1 to 15 of 29
Thread: Gas Cap Door
    Feb 2005
    2001 Ebony VX 0448
    Gas Cap Door
    I've seen this mentioned before and I thought it was true but it isn't: the key is not needed to close the cas cap filler door. I was in for my biannual emissions check and I had unlocked and left open the door so the gas cap could be pressure tested. I was watching the tech do the test in the side view mirror and was preparing to offer him the key to enable him to close the door when he just pushed it shut as easy as pie. I tried it later myself and sure enough, it just pushes shut like most normal cars. I have no idea why I never tried this before myself.
    Thanked: 7
    I think several years ago we had a thread about this. Half of us needed the key to close the cap and the other half just needed to close it shut to lock it.
    keyless closure here
    Anita
    2000 Ebony #263
    AnitaProtich.com
    Hey Irwin...
    I know on the old '99 we still have to use the key to lock her up...it sounds like on the '00 and '01 they make a little improvement.
    John
    I need the key on both of the '01s.
    I am jealous of those who don't need it.
    hey...WHAT'S UP WITH THIS????
    This is really weird.... 1/2 do and 1/2 don't :wtfg:
    I'm totally corn-fused.
    John
    '99 Ebony VX #0038
    It may not be quite a solution, but I think I've got the answer: it must be adjustable.
    I know this because when I first bought my VX in 99, I could shut the gas cap door without the key. It worked this way for several years, until I needed to get some rear end body work. Ever since I got it back from the shop, I've had to use the key. However, they did not swap any parts, so I'd be willing to bet if someone gets in there and fools around a bit, there is some play in the way the latch goes together and it can be adjusted in such a way that you can close the door without the key.
    There's no PN (that I could find) for the lock cylinder, nor was there any provision for adjustability (just removal). Both of my gas door latches contact the edge of the trim ring unless I move them aside with the key.
    I circled the interference here:
    2000,silver,vehicross,0460
    Got an '00 and I need the key, too
    2001foxfire0203
    01 needing key also
    2001,silver,906
    01 and I need the key..
    Dec 2004
    1999, Black, Vehicross, 1984
    I never needed the key until I broke the door off. Now that its replaced, I need a key.
    OK...I have it figured out!!!
    If you don't need a key to close the gas door....IT'S BROKE
    If you need a key to close the gas door....IT'S GOOD
    LOL
    John
    '99 Ebony VX #0038
    thebear54 -
    You very well may be right, but it's still a PITA to have to close your gas cap door with a key. I'd rather it if mine were broke again!
    Arrow
    OK people, I've been watching this thread for a while...& I finally couldn't take it any more. Yes, I actually went out & looked in my gas door.
    The gold colored metal "catch" that engages the mechanism can be bent back (to the left looking at it) to ease closing.
    The bracket holding the rubber "stop" can also be manipulated in or out to adjust where the door is in relation to the frame.
    The cap screws around the perimeter hold it all together. I've replaced mine with stainless steel, just because I like the way it looks...but be warned,it's a real PITA getting the nuts back on the backside of the catch & the stop, & they WILL drop down into a place where they are nearly impossible to retrieve if you don't have a finger on em during disassembly.
    Also, & this is just opinion, all VX gas doors can be closed w/o the key...you're just not slamming it hard enough. Look in there at the strike plate/catch on the left side to see what I mean.
    Ok, rant off...thats my "farmboy engineering" tutorial on gascap doors, take it for what it's worth (about what you paid), class dismissed.
    Ldub :winkr: :winkr: :winkr:
    Thanked: 7
    Quote Originally Posted by thebear54
    LOL
    John
    No no no! Ever since I bought my 2000 I never had to use the key to close. Not broken - just special :razg2:
  1. Door Seal being Torn by door
    By Techy-D in forum VX Troubleshooting...
    Last Post: 11/29/2006, 09:56 AM
  2. 2 door suv
    By Mark B in forum VX Talk...
    Last Post: 08/23/2006, 05:12 PM
  3. 5-door VX?
    By VehiFreak PDX in forum VX Modifications...
    Last Post: 10/16/2004, 06:55 AM
  4. Door Damage /Door Skin/Body Shop Experts!
    By USS Enterprise in forum VX Talk...
    Last Post: 03/12/2004, 06:13 PM
  5. 4 door VX
    By VXD959 in forum VX Modifications...
    Last Post: 06/19/2003, 07:50 PM
