Results 1 to 7 of 7
Thread: Hella E1 Airhorns
    '99 Ebony VX #0038
    Hella E1 Airhorns
    I bought a set of Hella airhorns from NYC #1 Ironman a few weeks back, but don't really know how to wire them up or the best place to mount them. I know there are a few folks here that have them - could someone give me a quick howto? Did you disconnect the stock horn, or run them parallel? Thanks in advance...
    '99 Ebony VX #0038
    *bump*
    Anyone? Is this just a matter of piggybacking off the original horns? Should I bypass the two original horns entirely, use one + the hellas, or use them all? Any suggestions would be appreciated.
    2001,Ebony,VehiCROSS,1092
    Kpaske,
    when I installed mine, I disconnected the original horns and used the existing wiring to hook them up. Since there is already a relay in the factory wiring, there is no need to install an additional relay. I removed the passenger side horn and fabbed a small braket to mount both horns on the factory mount. This positioned the horns close together facing down just behind the cladding. It was a struggle to mount them there and took some acrobatics - but easier than removing the cladding - hope this helps!
    May 2004
    No VX anymore. :(
    I want to add a note - I installed my triple air-horns a few weeks back, and they sound awesome. Perfect loudness - better than stock, but not a train blast - and different from anything I've heard, almost like a Ferrari, but not quite.
    Steve
    Apr 2003
    1999,white,ironman,1497
    Question Airhorns Illegal???
    I understood that putting airhorns on vehicle other than a diesel truck or similar may be illegal in some of the more anal states, like California or New York
    May 2005
    '99 Victory White Ironman #0194
    California Vehicle Code
    I think I can field this one, for Californians at least...
    CVC§ 27000 - Horns or Warning Devices
    (a) Every motor vehicle, when operated upon a highway, shall be equipped with a horn in good working order and capable of emitting sound audible under normal conditions from a distance of not less than 200 feet, but no horn shall emit an unreasonably loud or harsh sound. An authorized emergency vehicle may be equipped with, and use in conjunction with the siren on that vehicle, an air horn which emits sounds that do not comply with the requirements of this section.
    Which means that they are not illegal, but "unreasonably loud or harsh" is at the descretion of the officer. You could always fight it in court especially if it is close to the tock horns decible level.
    And while we are at it, you would more probably be cited for unnecissary use:
    CVC§ 27001 - Use of Horns
    (a) The driver of a motor vehicle when reasonably necessary to insure safe operation shall give audible warning with his horn.
    There ya go...
    May 2005
    And one caveat... This doesn't mean that your city and/or county doesn't have an ordinance prohibiting their use. Check with your local agency for an answer to that.
  1. Westin Bar and Hella 500 lights installed!
    By Front_rangeVX in forum VX Modifications...
    Last Post: 02/28/2014, 10:45 AM
  2. hella black magic
    By whitebreadx in forum VX Talk...
    Last Post: 02/15/2013, 08:08 PM
  3. HID conversions- Hella driving lights
    By pbkid in forum Chit-Chat ...
    Last Post: 06/15/2010, 01:56 PM
  4. Converting the Hella Micro DE to HID
    Last Post: 06/07/2008, 08:50 PM
  5. Hella Rallye 4000's
    By Hotsauce in forum VX Modifications...
    Last Post: 03/25/2006, 07:13 PM
