Results 1 to 15 of 15
Thread: car audio project
    1999, sliver, vehicross 0782
    is your subwoofer the jl w6? what's the length of it? mine jl w7 has a 9.25" length, i just dont know what to do in order to place it nicely. the depth of the spare tire well is about 7", and no matter how i put the sub, it just dont sound right. any suggestion?
    http://brocksrsxaudio.tripod.com/ima...target=tlx_new
    blue HID head light, custom license plate "GOVEHIX", Pro M mass air flow, black safari light bar from Tone, PIAA 194 fog light intalled, PIAA 550 fog light lamp installed, custom bull bar extention installed, Levoc ultra metal pedal set, Bioharzard sticker at the rear glass, Recaro red cellphone holder and razo steer cover.
    Occupation: Full Time VX Driver
    anyone knows what kinda powercable should i use? 2 gauge or 4 gauge? and what's really means? i am so new to all these things.thx
    1999, Ebony Black, VX ,1976
    it will not sound right when not it an enclosure. the mounting depth for that sub is 9.5" minimum.and as far as the power wire. the manual says:
    "The 1000/1's “+12 VDC” and “Ground”
    connections are designed to accept 4 AWG power
    wire. 4 AWG is the only recommended
    power wire size for this amplifier.
    If you are installing the 1000/1 with other
    amplifiers and wish to use a single main power wire,
    use 2 AWG or 1/0 AWG main power wire
    (depending on the overall current demands of all
    the amplifiers in the system).This 2 AWG or
    1/0 AWG power wire should terminate into a
    distribution block mounted as close to the amplifiers
    as possible and should connect to the 1000/1 with
    4 AWG power wire."
    i would use at least 2 gauge wire and use a distribution block to convert to 4 gauge.it also says to use 100 amp fuse:
    "FUSE REQUIREMENTS
    It is absolutely vital that the main power
    lead to the amplifier(s) in the system be fused
    within 18 inches (45 cm) of the positive battery
    post connection.The fuse value at each power
    wire should be high enough for all of the
    equipment being run from that power wire.
    If only the 1000/1 is being run from that power
    wire, we recommend a 100A ANL (large bladetype
    fuse pictured below) be used.
    No fuse is required directly before the amplifier
    power connection. If one is desired at this
    location, we recommend the use of a 100A ANL
    fuse for each 1000/1." shawn
    1COOLVX
  1. My project car
    Last Post: 02/22/2009, 09:36 PM
  2. need some audio help
    Last Post: 02/22/2009, 09:15 PM
  3. AUX/in audio?
    Last Post: 07/31/2006, 09:28 AM
  4. car audio?
    By 9tinyfingaz in forum VX Modifications...
    Last Post: 06/09/2006, 09:34 AM
  5. audio set up
    By pbkid in forum VX Modifications...
    Last Post: 05/10/2006, 02:10 PM
