Idling Problems
I need your help. The PVC hose on my VX is disconnected from the engine. I have an SC installed, if this makes a difference, to the place that the hose should be connected. I know that it is connected on the back of the SC or some place close, on the back of the engine. The symptom that I had was Idling problems, the problem was to low idle, the engine turns off at any time.
If you have a picture or drawing I will appreciate it, since there is limitted space to work and to see a picture would be great help. Thanks.
Frankie
From The Pearl Of The Caribbean
