Results 1 to 11 of 11
Thread: VX won't Start!!!!!!!!!!!
    May 2003
    2001,Dragon,VX1105
    Angry VX won't Start!!!!!!!!!!!
    I went out to start it this morning and nothing only a stuttering sound from the ignition. I checked the oil and the dipstick is bone dry...........
    I can't believe this. I was hoping it is the battery, but radio and lights work fine.
    Dec 2004
    Could be a lot of things, Joe. You might have a good battery, but a bad starter. Top off your oil, though - that should never be a surprise to have low oil. If you didn't see it coming, you have not been monitoring it closely enough.
    Starter? Definately fill the oil first though!
    Vehigaz...you must have been sending as I was typing!
    Apr 2003
    2001 Ironman #0276
    I had the exact same thing happen to me last week. Engine wouldn't start, sounded like the starter crapped out or the engine wouldn't budge (I don't know the difference). Thought it was the battery, so I charged it overnight. Radio worked fine, lights, doors, etc. were good. Still wouldn't start. Dipstick was dry as a bone. Uh-oh. Put more oil in, still wouldn't start. Had the car towed, but it turned out to be just a dead battery. Replaced it and everything else is fine now.
    Dec 2004
    Triathlete... HAH!!! What a funny co-inky-dink!!!
    Yes, don't forget that your battery may be strong enough to run the radio and lights, but not strong enough to turn the engine over. Unfortunately, the only way to tell what's going on is from the sound it is making.
    Sep 2004
    1999, Astral Silver, VX, 0938
    Next time with the headlights on try and turn it over, if the headlights go real dim or out your battery is low but if the headlights dim about half or just alittle your battery has enough juice. This is just a quick check if your out stranded.
    May 2003
    2001,Dragon,VX1105
    Thanks!!!!
    Thanks for the info guys........
    You save me a lot of money in towing charges......
    The problem was the battery. I replaced it and everything seems fine. I still want to have everything checked to make sure it's not the alternator.
    Question
    Joe,
    My question would have to be..Where did all the oil go? Yours was not the first VX that showed the same symptoms(No start,no oil). Any guesses from anybody? Is there a corollation between the oil and the battery, starter or alternator? Nothing I can think of.
    John
    The oil fairies .... okay, maybe not but there are several threads on this topic! Good luck...hope its nothing serious.
    The relationship would be less than ideal maintenance on the vehicle. Oil needs to be checked at least weekly and more if you drive long or hard. Hope it hadn't been driven too long with that low level of oil....when was it checked last? Regular oil changes are VERY important to the life of any small engine and ours specifically. A good battery like an Optima are much more foregiving of leaving the interior light on.
    May 2003
    2001,Dragon,VX1105
    Quote Originally Posted by Tone
    I have to admit that I have not been checking the oil regularly. I do change it every 6 to 8 weeks (when commuting) and was planning to have it done this weekend. I have never found it more that a quart low......
  1. won't start
    By simonsayz1 in forum VX Talk...
    Last Post: 11/25/2014, 11:38 AM
  2. Where to start?
    By dohvb1 in forum VX Troubleshooting...
    Last Post: 10/29/2012, 09:40 PM
  3. Will NOT start!!!
    By VXNIT in forum VX Troubleshooting...
    Last Post: 10/26/2007, 11:04 AM
  4. Help! Won't start
    By ISCE in forum VX Troubleshooting...
    Last Post: 12/14/2003, 04:20 PM
  5. HELP!!! Sometimes Won't Start
    By chumone in forum VX Troubleshooting...
    Last Post: 10/20/2003, 08:20 PM
