Results 1 to 15 of 25
Thread: Long Term Storage
    Dec 2004
    1999, Black, Vehicross, 1984
    Long Term Storage
    I wanted to write a thread yesterday saying how much I love this site and all its wonderful people with their big VX brains, but I had no internet. So I say it now. PRAISE VEHICROSS.INFO AND ITS MEMBERS! Now for my questions...
    On October 4th I will be travelling to the Portugal's island of Madeira to stay in Funchal for a year or two. I cannot bare to part with my VX forever so I will NOT be selling it. What can I do to prepare it for a long sit?
    I recently moved into a house with a bomb proof underground garage that can be sealed and only I know the passcode. I even installed a motion sensor activated camera to record people outside it. SO I AM ALL SET WITH SECURITY, but should I drain the oil? empty or fill gas tank? I have heard car covers leave marks on the paint over time, but is that just in the sun?
    Also should I put it on blocks to take strain off shocks? At first I thought that was a good idea, but I remembered what happened to the support shocks in my old hatch back. I left hatch open for a year and the shocks had no resistance when I came back.
    Is there something I can spray on the tires to prevent drying? I know if it sits on ground the tires won't be round when I get back.
    I want my baby to be just like I left her.
    Thanks in advance for your help guys and girls.
    Aug 2005
    Black, 1997 JDM
    A friend of mine left his old porsche in his garage for a couple of years. He recommends to:
    - remove the battery
    - remove the tires ( tire rubbers expire after some duration )
    - sit the car on concrete blocks
    - leave gas and oil inside ( rust appears if steel is dry )
    - cover with fabric ( sheets will do )
    Upon your return, you will need to drain the oil for particles especially in the transmission and engine oil, buy a new battery and tires.
    Some rubber and plastic parts had to be changed due to decomposition such as door seals, window seals and the windshield wiper. You might want to remove the windshield wipers too.
    Rats got to his wirings though. LOL!
    You may want to add oil and fuel stabalizers. That will prevent the fuel and oil from breaking down and forming varnishes which can dry and be harmfull also. If you can't find them in an auto store try a marine shop. They are commonly used for boats while they are stored.
    Oh yea...and rat traps!
    Dec 2004
    Thanks guys. My tires are fairly new so I will take them off and see how they hold up sitting on their sides. Just seems like such a waste, they still have the little hairs on the side.
    The garage is pretty rat proof, but I will get the traps just in case. Wouldn't be the first time they proved me wrong.
    When I put the car on blocks, I put the frame on blocks, not the suspension?
    Thanks for the great tips guys!
    Arrow
    Another thing you can check out : I think it's Sta Bil that makes an aerosol "fogger" to coat metal parts such as cylinder walls etc.
    Ldub
    Aug 2005
    Black, 1997 JDM
    Quote Originally Posted by LiquidVX
    I would advise to sell the tires as they do have an expiration date ( they harden ). Frame on blocks.
    Dec 2004
    Oh yeah. I didn't even think to sell them. Good idea. Thanks.
    Dec 2004
    '99 VX Astral Silver #0949
    As mentioned above, fuel filled and stabilized, fogging the cylinders, batteries, and protect from freezing are most important, but I have friends that even pull their valve covers and back off all the valve springs, since some are compressed and some are not.
    Or you could just bring it to my house and I will gently drive it around the block a few times a week just to keep things functioning properly!
    [IMG][/IMG]
    Jan 2004
    2000 Black Trooper 3248
    Gas stabilizer (Sta-Bil) is a must. Add double the dose, as per the instructions on the bottle. (The bottle says double the one year dose for two year application).
    DRIVE THE VX AROUND AFTERWARDS. You must get the stabilizer mixed around and into the fuel lines or it won't do you any good.
    I don't know anything about oil stabilizers for storage, I've never used them.
    However, for the engine, I would use the Sta-bil fogging oil.
    http://www.goldeagle.com/sta-bil/products.htm
    Here's what I would change when I got back:
    -Oil + Filter
    -Fuel Filter
    Consider the following:
    -Trans Fluid
    -Brake Fluid (absorbs moisture over time anyway, which lowers the boiling point)
    -Coolant
    Speaking of humidity, is your shelter climate controlled? Can you control the humidity? I'm not certain of the optimum point, but it's somewhere in the middle to balance drying of rubber parts and corrosion of metal parts.
    This looks pretty cool too:
    http://permabag.com/auto.htm
    Nate
    2000, Black VX #0754
    Quote Originally Posted by Mantronix7
    ...Rats got to his wirings though. LOL!
    I've heard that if you leave shavings of Irish Spring bar soap in or around the car that roadents don't like the smell and will stay away.
    A friend of mine has a plastic travel soap box filled with Irish Spring soap shavings in his classic Chevy Impala. When he leaves car for long periods of time in his garage he leaves the box open on the seat. When he takes the car out for a drive he closes the box and puts it in the glove box.
    Another friend of mine has a car bubble.
    www.carcapsule.com/
    '01 Ironman
    I think you should leave me your lattitude and longitude and your combo to get into the bomb garage... 'cus God forbid the lower 48 gets nuked to a pile of sand and you don't seem to make it/want to come back from Portugal.... I mean what will the poor VX do? Stay locked up underground for eternity? No I will not let this happen, now send me your info!
    Dec 2004
    Lots of good info guys! I didn't really want to take her apart, so i don't think I will back off the valve springs. Can I just spray the fogger into the air intake? That car bubble is pretty cool, but a bit on the ridiculous side, and I am limited on space.
    As for the VX's where abouts and driving it off a cliff....
    NO WAY!
    LOL
    Hey Alaska, I bought the same post apocolyptic tires as you, so she will be waiting for ME after the dust settles. Mickey Thompson's Baja Belted, THEY ROCK. Too bad I have to sell them.
    Dec 2004
    Portugal Kevin?!?! Where did this come from? What are you going to be doing there?
    Hey, I'll swing by 'Staven and take her around the block every month or so if you want. That'll keep everything nice and fresh. Seriously... it would be no problem.
    And, I'll probably take those tires off your hands, too. Are they 16s or 18s? And what do you want for them?
  1. Tires from Storage
    By Mile High VX in forum Wheels and Tires
    Last Post: 08/14/2014, 05:22 AM
  2. Short-term Review: Rancho MyRide
    By RickOKC in forum VX Modifications...
    Last Post: 12/20/2011, 08:07 PM
  3. Long term storage redux
    By fuzzy in forum VX Talk...
    Last Post: 10/12/2008, 06:33 PM
  4. Storage Suggestions ?
    Last Post: 09/10/2007, 07:37 PM
  5. Storage bin idea
    By Raque Thomas in forum VX Modifications...
    Last Post: 07/14/2005, 11:44 PM
