Results 1 to 4 of 4
Thread: Suggestion tune up
    1999 grey vehicross
    Suggestion tune up
    Does anyone has any idea what parts can I buy to autozone or Pepboys for my VX to tune up my car?
    Thanks in advance
    '01 Ironman
    spark plugs, PCV valve, differential oil, transmission oil, engine oil, engine oil filter, grease for drive shaft zerks, grease for wheel bearing repack, air filter
    seafoam treatment (i am looking into trying this)
    2001,Ebony,VehiCROSS,1092
    Quote Originally Posted by AlaskaVX
    PCV valve
    Make sure you get the one piece PCV valve - one of these guys (Pep Boys, I believe) carries a two piecer that set off my check engine light and cost me $70 to find out what the cause was. It apparently doesn't seal well between the 2 pieces after some use and vibration - letting air into the system.
    The Purolator unit from Pep Boys is one piece.
    You can also get a new battery (if you need one, I suggest an Optima red) from Pep Boys. Also, you can find trim-to-fit mudflaps there.
    Also stock up on degreaser and 'carb' cleaner. It'll make routine maintenance a lot easier if you keep your engine compartment clean.
  1. Tune up
    By karrijp in forum VX Talk...
    Last Post: 09/21/2012, 10:30 AM
  2. Suggestion for pet kennels...
    By VXIRONwoMAN in forum Chit-Chat ...
    Last Post: 04/18/2010, 03:06 PM
  3. Suggestion for those with Superchargers
    By Nazrat in forum VX Modifications...
    Last Post: 03/22/2005, 04:07 PM
  4. Need suggestion on new tires...
    By VXD959 in forum VX Talk...
    Last Post: 01/16/2005, 04:17 PM
  5. 30k tune up..
    Last Post: 03/27/2004, 10:52 AM
